Replaced two boards relating to monitor. Monitor now working but have "607 PC" error code. Can't move table, switch to edit mode, MDI mode, etc?
Any help is appreciated.
Thank you.
Thank you.
quote from maintenance manual: "data transferring error took place in MDI & CRT".
This would be related to the MDI board, cable or the motherboard, not the CRT.
mem. is correct did u swap the connection bds ( I/O ) boards. look at the jumpers.
also the string that goes from DIo out of the bottom of the M/B to first i/o to second i/o and on to the mdi pcb ( cables)
