586,106 active members*
3,012 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Communication problem through CH 4 in Fanuc 21i-TB control
Results 1 to 14 of 14
    Jun 2010
    30
    I have a Bridgeport Powerpath 15 with Fanuc 21i-TB control. On it's setting screen it indicates channels (1~3) which are used for communication through RS232C. The machine is also equipped with PCMCIA slot located to the left of LCD. It accepts CF Cards but the manual says that we should select Channel 4 for reading through CF card but it is not shown on setting screen. Please tell me how we can activate channel 4 on the setting screen?
    May 2009
    181
    Quote Originally Posted by humak16 View Post
    just make parameter 20=4
    Mar 2006
    167
    Or on the Setting (handy) screen, in the box next to I/O channel, type 4 and press input
    Jun 2010
    30
    I have tried by changing Setting parameter 20=4 but it did not work. When I press the soft key 'CARD' It gives alarm Message ' Memory Card Error 1010. IN fact the machine shows only 0~3 I/O Channels on setting handy screen. whereas on other machines it shows 0~35 I/O channel Nos. for selection
    May 2009
    181
    what card are you using..
    Jun 2010
    30
    I am using CF Cards ( 512MB) capacity. These cards work good with other CNC Milling and Turning machine having Fanuc 21i control. I think on setting (handy) screen, No. 4 option is not available for selection on this machine. Option for selection is available for 0-3 channels. How I can activate this option on setting screen. The setting screen shows as follows:
    I/O channels = 0 (0-3; Channel No.)
    When I change it to 4 and try to read through CF card inserted in PCMCIA slot , it gives error message "Memory Card Error :1010
    [email protected]
    Mar 2010
    You may want to look at your pins inside the PCMCIA slot on the machine because two years ago I got a new supermax with mxp-200I contol and while the machine was brand new I had two pins bent over in the slot and got the same alarm as you.
    Jun 2010
    30
    I have checked pin connections these are fine. Memory card also works good with other machines. Is there any special parameter which activates Channel 4?
    humak16
    Mar 2010
    I see you have already tried changing parmeter 20 and that is the one on my machines. One other silly question is have you opened the cabnit to make sure that you have a cable running to a card for the pcmcia slot
    Jun 2010
    30
    I have checked the cable from PCMCIA to Mother BOard. It is intact.
    Feb 2006
    1792
    Were you able to store 4 in param 20?
    Jun 2010
    30
    Dear Sinha,
    Yes the control accepts 4 in Para#20.
    Hold the two right hand soft keys
    Power on the control
    use the soft keys to navigate to Memory card format
    Press Select
    Press Yes
    Press Select
    navigate to end
    press select
    navigate to end
    Press select
    If at any point you get a memory card error on this screen there is some thing physically wrong i.e incompatible card or physical defect
    if the format works correctly re try the CARD softkey
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
    Jan 2010
    7
    Early 21i series controls don't accept CF cards. You may have to use SRAM card instead.
    ATB
    Alge
  1. RS232 communication on Fanuc 21i-TB control
    By dittrichw in forum Fanuc
    Last Post: 06-09-2008, 12:02 PM
  2. Fanuc OT communication problem
    By ECM2004 in forum MetalWork Discussion
    Last Post: 06-07-2007, 01:05 PM
  3. Fanuc Om Communication Problem
    By aghobby in forum Fanuc
    Last Post: 02-27-2007, 07:01 PM
  4. Help! RS232 Communication to Fanuc 3T Control
    By m1_machine in forum Fanuc
    Last Post: 10-30-2006, 09:08 PM
  5. Fanuc control problem
    By wilsontool in forum Fanuc
    Last Post: 10-12-2006, 07:56 PM
