586,055 active members*
4,176 visitors online*
Results 1 to 6 of 6
    Nov 2005
    57
    Mazatrol m2 runs only 9999 blocks
    Can somebody answer if mazatrol cam m2
    in ISO mode is able to run more then 9999 blocks,
    and in case how?
    Thank you
    Sven.
    2932
    I would assume it will only display N4 digits, but will run a program over 9999 blocks. Can you remove the N numbers from your program? In most cases they just use up memory.
    Nov 2005
    57
    Its not that,it is the problem then you have more then four digits
    like N10001 it will stop and saying nummerical is out off range.
    Sven
    Nov 2004
    260
    Quote Originally Posted by sve0019 View Post
    Sven
    I belive this can be set at the Cam Post to use only 4 digit numbers, it will then just start the count over with N0001 and continue.
    Of cause you could just simply get rid of the numbers too.
    2932
    Sven
    As I said, why not remove the N numbers, or just number the tool changes or as Torsten suggests if your CAM system will do it, limit your N numbers to 4 digits.
    Nov 2005
    57
    In the postprocessor I was setting sequence numbers to four,
    and N numbers to N like no.
    With thanks from Sven for helping out.
    End off problem.
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  2. Sm1 well versed with mazatrol 640m or atleast ne mazatrol
    By naren1608 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-22-2010, 11:29 AM
  3. A way around the 9999 program line limitation?
    By Sierra Nevada in forum Fanuc
    Last Post: 01-05-2010, 08:43 AM
  4. KL5056 runs one way only
    By Filobus in forum Automation Technology Products
    Last Post: 09-11-2007, 02:52 AM
  5. X3 Mill just runs by it self
    By replicapro in forum Uncategorised MetalWorking Machines
    Last Post: 08-20-2004, 05:32 PM
