586,036 active members*
4,068 visitors online*
Results 1 to 2 of 2
    Jul 2010
    Camtech Router Master II Issues
    We have a secondhand Camtech Router Master II that we are having issues with and would appreciate any advice:
    We are having problems with the machine not cutting square even though we regularly maintain the chain tension.
    We have replaced the chains as well as made sure the cogs on the drive motors are not slipping.
    It is also wanting to stall when it is running along the x-axis, this is causing tools not to change properly and does not cut things out correctly.
    We always ensure everything is greased properly, and frequently..
    Aug 2010
    6
    hi i have camtech z10
    & i have an issue in it who can help me pleas
    the Axis Z left
    is not linked with
    Z & Y & Z right what can i do?
  1. CamTech RM25 router with Mach3
    By DennisCNC in forum Commercial CNC Wood Routers
    Last Post: 11-10-2012, 12:15 AM
  2. Camtech 52 Router
    By 21stcenturypl in forum Want To Buy...Need help!
    Last Post: 09-09-2011, 09:54 AM
  3. Master cam issues
    By Pat22089 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-27-2010, 06:30 PM
  4. Motion Master Router with AB9/260
    By alexplace2001 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-03-2009, 06:59 PM
  5. Motion Master router
    By Jennifer in forum DIY CNC Router Table Machines
    Last Post: 10-16-2004, 05:26 PM
