586,115 active members*
3,458 visitors online*
Results 1 to 7 of 7
    Mar 2009
    144
    Beaded belt drive parts needed
    Hello all...
    I work with some older laboratory instrumentation and have been slowly, but steadily running out of a particular little part. This little beaded string couples a rolling numerical display to the drive system has become increasingly rare.
    I've looked all over through google searches and had no luck in finding a supplier so I'm posting here looking for any suggestions. Considering where I'm posting though, I thought someone might have some ideas on how to fabricate something like this. The beads are 3mm in diameter plastic on a tightly woven string of some kind.
    I have a mill and considered building some type of injection molding form, but that's as far as I've gone towards fabrication.
    Ken
    Aug 2008
    573
    Looks similar to the beaded string used on blinds
    http://www.blindsdiy.co.uk/acatalog/Spare_Parts.html
    Bill
    Mar 2009
    144
    That's not a half bad idea... My specs are fairly precise, but maybe I'll get lucky. I'll look for a US supplier who can measure their product... Thanks!
    Ken
    Mar 2006
    202
    Berg has some funky cable with lugs. Put '31GBF' into the link's search box for some examples. There are no doubt more but their web site makes it difficult to browse products.
    Mar 2009
    144
    Thanks... I've been looking through their online catalog and this is much closer, but never quite what I need. Really good info though. You're right about it being really hard to navigate.
    Ken
    Apr 2007
    1955
    Perhaps it would be easier to consider changing out the drive pulley to a small toothed belt system?
    Here is one example firm, but there are a number of others.
    http://brecoflex.com/index.php?CATID=1&SCATID=1
    Mar 2009
    144
    Harryn,
    Thanks for the suggestion, but the really unique thing about a beaded belt is that it can easily transmit drive force between pulleys rotating on vertical and horizontal axes. That's what this belt is doing. The Berg belts are about the only thing I've seen that's even close. Seems like the "ball" technology may have simply been replaced by the "bar" style. If I'm really lucky, I might be able to simply modify the current pulleys (there are several on each machine) to accept the bar style chain.
    Ken
  1. Direct Drive Vs Belt Drive for a Mill/Drill Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2012, 09:12 AM
  2. belt reduction, parts suggestions needed!
    By tmbg in forum Mechanical Calculations/Engineering Design
    Last Post: 06-28-2010, 03:51 PM
  3. Belt drive instuctions needed for X2
    By kiramunch@sympa in forum Benchtop Machines
    Last Post: 03-02-2010, 09:06 PM
  4. Need Sherline Belt & qestion on X2 Belt Drive?
    By Oldboy in forum Benchtop Machines
    Last Post: 03-06-2008, 07:42 AM
  5. Belt Drive - advice needed
    By Pat2000 in forum Linear and Rotary Motion
    Last Post: 11-01-2005, 03:11 PM
