They are, NC, in series, and not showing any yellow trip lites in the Mach diagnostics screen. I tested them with my DMM and all are working fine, I also checked the wires and there is continuity all the way around, I manually actuated the switches and checked that the loop opened.
I don't do cnc yet, so take this with a grain of salt, or dump it if someone else chimes in.
So, you have a loop of continuous wire that runs through the switches, unless one is open. If you open that up, it should think you hit a limit and stop the mill, presumably with an error. I would run it and open that loop and see if it stops and gives an error. If you can unplug something to accomplish this, that would be the easy/non-destructive way. If you can (safely) reach a switch with it running and open the switch, that would be a good test. Maybe use a pencil to activate one? Safe and the pencil won't likely damage the works. If you are fed up and want to get rough with it, snip a wire, opening the circuit. If you cut the wire with it running, it should think you hit an end limit, as well as burn off some aggravation (nuts) Might be not a good idea. Maybe you can just unplug it from a connector?
If you can find a way to open the circuit, it should think you hit a end limit and (presumably) stop the mill and give error. Maybe you can wiggle the micro-switches with a pencil while it runs? It should error out and stop if a switch opens. I hope someone offers better advice, but that's what I would try. If the circuit is opened, it should stop the mill. Please keep in mind, I've never seen one of these in person, and this is just what I would try. If any one offers advice, it's likely better than my blind shot at what to try.
Good luck!:rainfro:
Wen I was young, I spent most of my money on fast women, slow horses, and cheap booze. The rest of it I just wasted.
