It's a two part questions.
The first is I followed the the Haas installation manual and rough level the VF-2SS, but encountered the following problem during the fine leveling of the Y-axis.
Setting the level parallel to the Y-Axis
Level at the middle of the Y-Axis
Level at the back of the Y-Axis
Level at the front of the Y-Axis
X and Y axis level on the other 4 "cross" points are okay, except for the front y axis leveling. I tried adjusting the middle leveling screws and a variety of combinations but still could not achieve a better level. Looking at the level scale, I guess this kind falls within the +/- .0005" for the entire entire travel of the y-axis, but is this normal?
The machine sat unused for about 9 month resting on the 4 corner pad. Did resting on only 4 pads distorted the casting?
The second question is regarding the terminal connection from the breaker. The current wiring is as follows,
The building has 208V, however I noticed the input voltage fluctuates on average from 210 ~ 214V. Should I connect wires 74, 75, 76 to the 226-211V block instead of the 210~190V block? and what difference does it make?
John
