586,521 active members*
3,563 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > LEADWELL VMC 25 with MELADS M50 controller
Results 1 to 8 of 8
    Dec 2009
    958
    hi
    anyone have the mechanical book of a leadwell vmc 25 with meldas m50 controller?
    i have to chance the bearings on the spindel but i don't know the type of bearings so i need a spare parts book.
    also i loose everytime the G54 seetings when i change program.
    any help will be apreciated.
    maybe could have only the spindel page from the book scanned?
    many thanks!
    Mar 2009
    53
    I have the exact same machine. I am not in my machine shop right now but I will be glad to help you. I will look in the spare parts list tomorrow (GMT+1).
    I also have a question for you. Does your machine have the 4th (B) axis integrated?
    Question to other members:
    My machine has the B-axis on the control panel but there is no servo controller installed for it. Logically the machine reports an error if I try to move the B-axis. Would it be possible to attach an extra servo controller MDS-A-SVJ-10 in the control chain, adress it and assign it to the B-axis. I have a golden sun rotary table with a separate controller. The idea is to fully integrate this rotary table in the machine so I can do interpolation with the 4th axis. I need some amount of certainty before I buy a $1400,00
    2nd hand servo drive. I could also try sniffing on the control chain and design some interface between the NC and the external controller. But there must be a faster way, right?
    Kind greetings.
    Dec 2009
    958
    hi
    thank you for u help
    if u have a pdf file with spare parts i will apreciate if u can send it to me via email.
    thank you again in advance.
    HAVE A GOOD DAY!
    GOOD LUCK!
    PS:NO MY MACHINE HAS NOT 4 AXIS INTEGRATED BUT I CAN HELP U IF U HAVE QUESTIONS.
    Mar 2009
    53
    There are 2 sets of spindle bearings. Since you are taking apart the spindle assembly, I would change both. Each part number orders one set (2 bearings).
    C01AA09110, Spindle Bearing (UPPER SET), 2MM9110WIDULFS660
    C01AB09112, Spindle Bearing (LOWER SET), 2MM9112WIDUMFS660
    I will send you a copy of the drawing and the part list later when I get home from my shop. I do not have the time to copy the whole book because it is 50 pages and the drawings fold open -> difficult to copy.
    Kind greetings.
    Dec 2009
    958
    HI M8
    Thank you for your help.
    i understand, maybe only the page with the bearings will be enough for me.
    thank you again for your help.
    GOOD LUCK!
    Mar 2009
    53
    I have sent a pdf to your hotmail address. Good luck fixing the machine.
    Jun 2020
    Re: LEADWELL VMC 25 with MELADS M50 controller
    Hi.
    I see in this old thread that you EPTech have partslist for Leadwell VMC-25. Do you stil have it on PDF?
    I need some parts for my old machine.
    Thanks!!
    Mar 2009
    53
    Quote Originally Posted by GogB View Post
    Hi.
    Thanks!!
    I do not have the entire book in pdf. It is an awkward format to scan because all th papers fold out into big plans.If you tell me which parts you need I will scan the plans with the corresponding list.
  1. Leadwell with fanus OM controller
    By fattee in forum Fanuc
    Last Post: 05-27-2012, 08:45 AM
  2. leadwell mcvo controller alarm
    By monaro mike in forum Fanuc
    Last Post: 03-21-2008, 12:38 PM
  3. leadwell vmc 25-need help
    By _pk_rasta_ in forum Uncategorised MetalWorking Machines
    Last Post: 12-23-2007, 05:54 AM
  4. Help! Servo controller problem on Leadwell VMC
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 12-14-2007, 02:16 PM
  5. MCV-OP Leadwell????
    By bdrmachine in forum Uncategorised MetalWorking Machines
    Last Post: 02-16-2006, 02:35 AM
