586,052 active members*
3,935 visitors online*
    May 2005
    9
    Question units per inch math
    hi what is the formula for computing steps per inch
    for example 360/.9 degree half step=400 steps per turn.
    so 400*20tpi lead screw=8000 steps per inch.* 30:1 gear reduction
    ie 8000*30 =240000 steps will give me 1 inch.
    is my math correct or did my brain fart?
    Aug 2003
    73
    Yes your math is correct... Are you sure its 30:1 and not 3:1 ???
    I think 30:1 will be a big problem for you.
    That would give you a resolution of .000004 wich is way to much.. would also really limit the speed of your unit..
    Oct 2004
    590
    (steps/rev)*(rev's/rev)*(rev's/inch)=steps/inch
    Aug 2004
    2849
    Quote Originally Posted by OCNC
    Hmmm...that gives me step *rev's squared/inch rev squared
    Oct 2004
    590
    Quote Originally Posted by ViperTX
    [(step)*(rev^2)]/[(inch)*(rev^2)]
    The (rev^2) cancel and the units remaining are step/inch where inches are the linerar inches of travel.
  1. math needed to build a cnc
    By trubleshtr in forum Mechanical Calculations/Engineering Design
    Last Post: 03-16-2005, 08:20 PM
  2. DRO - Metric or Inch
    By DJ Morrow in forum CNC Machine Related Electronics
    Last Post: 11-15-2004, 09:06 PM
  3. Turns per inch to metric conversion
    By sixpence in forum DIY CNC Router Table Machines
    Last Post: 08-28-2004, 08:19 AM
  4. turns per inch vs threads per inch
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 08-18-2004, 03:27 PM
  5. Metric vs Inch - arguements pro & con
    By DJ Morrow in forum Mini Lathe
    Last Post: 08-12-2004, 02:46 PM
