586,036 active members*
3,576 visitors online*
Results 1 to 6 of 6
    Jun 2010
    104
    Tools Not Saved
    I recently purchased a Hurco BMC 4020 with an Ultimax 3 Controller. When I turn the machine on and define tools that are not saved? Is there something I'm missing to save them so the next time I turn the machine on they are there?
    Thanks in advance.
    Jul 2010
    492
    are you programming in nc or with the ultimax software? i know when i dont have a program loaded in nc when i shut off the machine, my machine will boot up and default to the conversational programming and my tools are not there. once i load an nc program tho, they return. i am guessing that you are having the same issue.....
    Jun 2010
    104
    Tools Not Saving
    Shane123,
    Thanks for the info. I haven't noticed it saving any tools. I typically don't use the mill in conversational mode but in Basic NC and BOBCad to create the programs. I modify them in BOBCad, load them into the machine via floppy disk. Last night, I thought to copy the program to the hard disk, then setup all the tools thinking this would help but nothing. There has gotta be a way. It is so painful re-defining the tools each time.
    Thanks to anyone who has information about this.
    Jul 2010
    492
    make sure you have a program loaded when you go to the tools section. thats about all i can guess, i have the hurco vmx42 with ultimax, winmax mill version v07.01.11.13 . I have my nc settings on industry standard, not basic. with basic, i was having issues with my post from mastercam x3.
    Jun 2008
    1104
    Go to the conversational side of the control, load up all your tools in a program that just has the tool setup in. Save this program under a name like "tools".
    When you go to the NC side, go to the restore functions and "restore tool setup". Find the file called "tools" and load it - Voila! all your tools data is there.
    Cheers!
    Jun 2010
    104
    Tools Not Saved
    bloke,
    Thanks! I will give that a try!
  1. COMMUNICATIONS SETTINGS NOT SAVED
    By CNC_BOB in forum Mastercam
    Last Post: 12-30-2009, 12:44 AM
  2. Demo Mode saved drawing
    By cncpilot in forum BobCad-Cam
    Last Post: 10-25-2009, 06:03 AM
  3. BCC v22 Speed/Feeds corrupted if file saved without post
    By brooklynmetal in forum BobCad-Cam
    Last Post: 03-25-2008, 02:33 PM
  4. port and pin settings not saved?
    By Block16 in forum Mach Mill
    Last Post: 09-26-2007, 02:13 PM
  5. NcPlot could have saved my butt
    By Karl_T in forum NCPlot G-Code editor / backplotter
    Last Post: 08-30-2006, 12:51 AM
