586,378 active members*
2,579 visitors online*
Page 23 of 76 1321222324253373
Results 441 to 460 of 1506
  1. #441
    The problem is the G91 G28 before the M0, putting Mach3 in Incremental mode.
    Looks like you can't do a G53 G0 move in Incremental mode. I'm actually surprised that it's taken this long for this to come up.
    Replace your M6End.m1s with this one, and you should be good.
    Attached Files Attached Files
  2. #442
    May 2009
    133
    Thanks.... Im goin to try it now. Brb! :-)
  3. #443
    May 2009
    133
    Do I still to edit the code and remove the M0s??
  4. #444
    You'll have to hit Cycle Start each time it gets to an M0, but you don't have to remove them if you don't want to.
  5. #445
    May 2009
    133
    It works Perfect!!!!!!! Thank you thank you thank you!!
  6. #446
    May 2009
    133
    Man this is GREAT Gerry!! :-)
    Last night I was ready to haul the thing to the scrap yard......
    I think ima go cut up a bunch stuff now just to watch it do a tool change!!!
    Thanks Again!!
    Goodnight!!
  7. #447
    May 2009
    133
    Btw.... You need a Donate button on your web page!!
    Your help was worth more then I paid for the screenset!!
  8. #448
    Click on the beer glass in the upper right corner of this post.
  9. #449
    May 2009
    133
    Done! :-)
  10. #450
    May 2009
    133
    Hello Gerry...
    I got a G53 Incremental error last night when I tried to send my machine to
    its park position. No big deal I can deal with it if necessary. Just thought I would let you know and see if you had any ideas of what it may be.
    Thanks. :-)
  11. #451
    Apparently, you're the only one using Incremental mode with this screenset.
    I can fix it, but you'll have to wait a little bit.
  12. #452
    Quote Originally Posted by MillworkMike View Post
    Hello Gerry...
    its park position.
    Replace the M883 with this one and you should be good.
  13. #453
    May 2009
    133
    Thanks Gerry! :-)
    I will give it a try tonight.
  14. #454
    French version now available
    Thanks to Jean-Philippe CIVADE, the French version of the 2010 Screenset is now available, and there's a link on my site to a French version of the page, with French version screenshots.
  15. #455
    May 2003
    96
    Hi Gerry,
    I've just had a look at your Mach3 2010 screenset and looks very neat and composed. I would like to know if you have or if there is the possibility of showing the A and B axis DRO. This follows for the simple reason that I am currently gathering all the materials and info to start building myself a 5 axis CNC router following my first build with 4 axis.
    Marting
    Martin G
  16. #456
    There's a 4 axis version with the A axis, and all the DRO's are shown on the Diagnostics page, but there are no plans for a 5 axis screen.
    One of my users mentioned to me earlier today that they may modify the screen for 5 axis, and will supply me the files when complete. But I have no time frame if and when it happens.
  17. #457
    Jan 2008
    932
    Gerry,
    What 'command' is sent in your screen set when you hit the little router icon/button?
    I have had a few issues with my system recently, now I find that button turns the router on and off, but m3/m30 no longer does... so I am trying to figure out what got scrambled.
    Paul
    Wood neophyte.
  18. #458
    Jan 2008
    932
    Eh, nevermind on the question. It seems my signal is reversed for router on/off. M5 starts it and M3 stops it. Hmm... wonder what is going on.
    Wood neophyte.
  19. #459
    Aug 2009
    136
    can someone help me. i have vcarve pro and i'm trying to do a tool change on it. i have .25 end mill as tool 1 and V90 bit as tool 2 in vcarve pro. all loaded into one tool path. but when i run the tool path in mach 3 2010 it very stops so i can change the tool. i i'm not using the same computor that the cnc is on, if that the problem.
    kevin
  20. #460
    Do you have Mach3 set to "Stop spindle, Wait for Cycle Start" in General Config? And are you using an ATC post in V-Carve Pro?
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
