586,067 active members*
5,437 visitors online*
Page 57 of 76 747555657585967
Results 1,121 to 1,140 of 1506
  1. #1121
    Sep 2005
    106
    Re: Mach3 2010 Screen set
    Thanks Gerry
  2. #1122
    Mar 2011
    59
    Hi Gerry,
    I've been enjoying the use of your screen set with my CNC router for several years now and really like it. The Auto Zero/Manual tool change feature is my favorite. However, I just noticed something happening with my SHORTER cutting bits. I zero out to the top of my stock with my movable plate (first tool already installed) with no issues. The machine moves to the fixed plate, does it's normal double touch, everything is good to go, but I load my g-code and click start, the first M6 is there as usual (I just leave these in and click start again) The machine begins probing downward to the fixed plate (3/4" below spoilboard surface) but doesn't make it all the way to touch, retracts slightly then attempts it's second soft touch, but doesn't make that either. The machine then acts like it's ready to work, but is now zeroed above the actual stock zero. IT IS JUST THE SHORT CUTTERS. The longer bits work just fine. I'm sure this is something simple to fix, I'm just not seeing the problem. Thank you.
    -- Bernie
  3. #1123
    The macros are programmed to only probe down 6", so you'll need to edit 3 macros, M881, M889, and M6End. Find the following sections, near the top of each one, and edit the appropriate value, depending on whether you use inches or mm's.
    If GetOEMLED(801) Then ' On = English Measure INCH
    FirstProbeDist = 6.0 ' Probe down 6 inches
    FirstRetractDist = 0.05 ' Then retract .05 inch
    SecProbeDist = 0.25 ' Then probe down .25 inches
    FirstProbeFeed = 10.0 ' First probe feed @ 10 ipm
    SecondProbeFeed = 1.0 ' Second probe feed @ 1 ipm
    ClearAllow = 0.125 ' Max Allowable Clearance = Z Machine Zero - .125in
    Else ' Off = Metric Measure MM
    FirstProbeDist = 150.0 ' Probe down 150mm
    FirstRetractDist = 1.0 ' Then retract 1mm
    SecProbeDist = 6.0 ' Then probe down 6mm
    FirstProbeFeed = 250.0 ' First probe feed @ 250 mm/min
    SecondProbeFeed = 25.0 ' Second probe feed @ 25 mm/min
    ClearAllow = 2.0 ' Max Allowable Clearance = Z Machine Zero - 2mm
    End If
  4. #1124
    Oct 2007
    446
    from my thread in the bobcad forums...
    Why isn't my gcode running??
    "Default Re: Why isn't my gcode running??
    I think it may be that particular screenset, I have just tested your code on 4 different Mach3 screensets and 2 different Mach4 screensets and it works on all of them, next I tried the 2010 screenset and I get the same issues as you so try a different screenset, the default 1024 screenset would be a good place to start, I found the 2010 one to be unstable and that was on a PC with XP Pro 32 bit OS which runs anything and everything
    Regards
    Rob"
    Not sure why its not running...using mach 3. This line flashes red in the readout and then nothing...just sits there...
    (TOOL #1 0.25 1/4 2 Flute LOC 1.125)
    any ideas?
    O100 (PROGRAM NUMBER)
    (BEGIN PREDATOR NC HEADER)
    (MCH_FILE=4AXVMILL.MCH)
    (COORD_SYS 1=X0 Y0 Z0)
    (MTOOL T1 S1 D0.25 C0. A0. H3.)
    (SBOX X-1. Y-7.1875 Z0. L6. W8. H0.75)
    (END PREDATOR NC HEADER)
    (FIRST MACHINE SETUP - Machine Setup - 1)
    (PROGRAM NAME - DUSTBOOT_TOPPLATE.TAP)
    (POST - BC_3X_MILL 3-AXIS GENERIC FANUC)
    (DATE - SAT. 02/13/2016)
    (TIME - 03:48PM)
    N01 G00 G17 G40 G49 G80 G20 G90
    (FIRST CUT - FIRST TOOL)
    (Machine Setup - 1 Facing)
    (FACING)
    N02 G90 G54 X-0.551 Y0.3 S1222 M03
    N03 G43 H1 D1 Z1.75
    N04 Z0.95
    N05 Z0.85
    any insight on this??
  5. #1125
    Oct 2007
    446
    ....seems to be finicky...sometimes it works and sometimes doesn't. I have to open and close mach, reload file and run it again until it works...
  6. #1126
    See my posts in your other thread.
  7. #1127
    Jul 2011
    5
    Hi Gerry,
    I've been using your screen for some time now and it works great!!
    I have one question I have a spindle that I need to warm up before the cnc starts cutting.
    The way it works now is after tool setup and so on cycle start the axis is moving and as it gets close
    To the fixture the spindle starts. is there any way to start the spindle for a minute or two before the axis move?
    Gus
  8. #1128
    Your best option is to probably create a simple g-code program that warms up the spindle.
    Something like this:
    S8000 M3
    G4 P30
    S10000
    G4 P30
    S15000
    G4 P60
    M5
    M30
    You can set a spindle delay in Mach3, but it would get old having to wait 2 minutes every time the spindle turned on.
  9. #1129
    Jul 2011
    5
    I will try that.
    I guess the code you wrote is 30 seconds @8000rpm 30 seconds @10000rpm and 60 seconds @15000rpm ?
    Thank you for the fast respond !!
  10. #1130
    Yes, you are correct.
  11. #1131
    Mar 2016
    I purchased this with my wife for the Mach 3 Screenset 2010 from thecncwoodworker.com website and got confirmation email on payment but no download link. Can you provide this to me please? I also sent an email. Hope to hear back both here and by email soon. Thank you Fred Grover.
  12. #1132
    Apr 2015
    48
    Hi Gerry, my name is Peter Pollard and I have purchased your Mach3 2010 screenset and received the payment confirmation if you need my email please pm me. Looking forward to using your great Mach3 add-on. Comes highly recommended from Peter of Homann Designs.
    Regards,
    Peter.
    Edit: received with in the hour great service
    Cheers Ger
  13. #1133
    Quote Originally Posted by Fred_Grover View Post
    The screenset was sent as an email attachment as soon as I woke up this morning.
  14. #1134
    Hello.
    I cant contact you on pm and e-mail so i wrote here,
    On 6 March i bought as in title over paypal, but anything of these files got onto my mail since this day. Could you send it again?
    Regards
  15. #1135
    Check the spam filter of the email address on your Paypal account. I sent you the files the day you ordered.
    If you still don't have them, please send me an alternate email address I can send them to.
    You can email me at cncwoodworker at comcast dot net
  16. #1136
    spam filter was already checked, i received nothing at my mailbox
  17. #1137
    I'll send again from my gmail account, but if you don't receive it, you need to give me a different email address.
  18. #1138
    alternative email addres jacek_jasinski_ at poczta dot onet dot pl
  19. #1139
    Quote Originally Posted by kombo_mcm View Post
    It wouldn't send to that address.
  20. #1140
    I just found out that my PM inbox was full. Sorry about that.
    It also looks like I mes-spelled your email address.
    Hopefully, you should now have the files.
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
