586,510 active members*
2,838 visitors online*
Page 66 of 76 16566465666768
Results 1,301 to 1,320 of 1506
  1. #1301
    Apr 2016
    100
    Re: Mach3 2010 Screen set
    That's wisdom. If it ain't broke, don't fix it.
    I've gotten into too much trouble over the years ignoring that advice.
    CNC hobbyist since 2003.
    Current CNC hardware: Sherline/A2ZCNC extended, 4 axis X/Y mill and Sherline lathe
  2. #1302
    I'm using the 2010 Screenset auto zero functionality and I'm trying to adjust my post processor file to work with it. My gcode post processor file has a G43Hx (x being the tool number) after the M6 which I have commented out. Is it needed? Harm to leave it in?
    Does this snippet of code before and after the M6 look correct for the auto zero to work??
    N2020 Y21.7249
    N2030G1 X89.7929
    N2040 Y22.7249
    N2050G0 Z1.2500
    N2060M5
    N2065 (Tool=3/8 Compression)
    N2070M6 T3
    N2080M3 S18000
    N2090G0 X34.8306 Y42.2928 Z1.2500
    N2100G0 Z0.2500
    N2110G1 Z0.0000 F70.0
    N2120G1 X35.8306 Z-0.7000 F70.0
    N2130G1 X55.9558 F200.0
    N2140 Y45.5428
  3. #1303
    I prefer to remove the G43, but if you don't have any tool lengths in your tool table, it shouldn't cause a problem.
    It looks fine like you have it.
    You just need an M5 before the M6, and the M3 S## after.
  4. #1304
    Thanks Gerry!
  5. #1305
    Dec 2013
    28
    Do you have a tool table with tool lengths recorded in it? If so t1 is you default 0 in order to get the other tools to auto 0 you should call a G0 G43 H(tool #) Z1.2500 after the M6 . This will send the new tool down to its 0 plus the Z dimension. Even if you don't have a ATC you can set Mach to pause at M6 so you can do a manual tool change and it will still offset to the new tool if its in the tool table correctly.
    Steve
    PS sorry I jumped ahead.The 2010 screen set have a probe call for an auto zero as a macro.
    I do like the looks of the screen set and will try it.
  6. #1306
    May 2005
    32
    What could be a possible cause of the z-axis cutting about 2 times its programed depth. We zero the z with a puck touch plate 0.625" thick.
    The axis is properly calibrated, we've used the machine by zeroing with a piece of paper and it cut as it should. The x and y axiis are fine, we manually zero these until we can make up a touch plate. When we use the 2010 simple auto zero its like it is not calculating something properly. We always have to press reset to prevent it from going into the table. We are not using material offset, it's set to zero and not selected. Its like some compensation is selected somewhere but we can't find it. The machine homes properly, goes to the proper park and tool change postion. Whenever we try the auto zero for the z-axis its always to deep no matter what we try.
    EDIT
    *The zero probe itself works i.e it will touch the probe twice then retract 1" ofF the work piece. Thats what makes it more baffling it must be getting the right distance but then you run the nc for the part and it goes to deep.
  7. #1307
    Jun 2010
    4256
    Hi Jake
    I have no idea what CNC HW you are running, but I guess you are using Mach3 at least.
    There is one reason why touch probing does not always work, and that is because the Chinese controller does not support g31 (the touch probe command) properly. We have seen this in the past. Could this be happening to you?
    Cheers
    Roger
  8. #1308
    May 2005
    32
    We are using a chinese controller, AKZ250 by leafboy.
    Leafboy77 - Mach3 Usb Motion Card (AKZ250)
    Is their a known issue with that particular controller? We were working on this for a couple of hours today. Its driving me nuts.
    the machine came with this hardware including the touch plate. Yes we are using MACH3, I don't recal the exact version, I'm at home now.
  9. #1309
    It's a known issue with most chinese controllers. Send me an email, and I'll send you some alternate macros to try.
  10. #1310
    May 2005
    32
    Thanks ger21
    email sent.
  11. #1311
    Jun 2010
    4256
    As Gerry said - known problem with the AKZ250.
    IF I remember correctly (that's IF), the AKZ250 stops where it should but does not report the XYZ values back to Mach3. However, the actual Z DRO value is quite close, especially if you were going slowly.
    Chinese controllers ...
    Cheers
    Roger
  12. #1312
    Dec 2013
    28
    Quote Originally Posted by jake76 View Post
    EDIT
    Are you zeroing it on the number 0 tool? This sets the base reference for the tool table then your offsets must be right on your other tools and there must be the H word (height) call before your Z move.. ie. N10 G0 G43 H2 Z0.100.This will rapid the Z down to tool offset #2 to .100 above set 0 with the G43 tlo call.
    Is the T number in the nc file the same as the one you are zeroing on?
    Good luck
    Steve
  13. #1313
    Jun 2010
    4256
    Yes, I can do that withOUT using the faulty returned Z value.
    Probe
    Back off 0.1" IN INCREMENTAL MODE
    Probe
    Back off 1" in incremental mode.
    Revert to absolute mode
    Cheers
    Roger
  14. #1314
    May 2005
    32
    Thanks RCaffin and Machine head 57.
    ger21 sent me some new scripts to try, I will also check all the things you mention when I'm back in the shop today. I do know for sure that we are set for tool 0.
  15. #1315
    With the 2010 Screenset, you do NOT want to use G43, and the tool # doesn't matter.
    Each tool is zeroed automatically, so no tool length offets are needed.
  16. #1316
    Dec 2013
    28
    So you are zeroing each tool as it is selected.
    Ok then no G43 and no tool table. maybe we need to see the start of the file that the problem is in .
    Steve
  17. #1317
    No, the problem is that the motion controller he's using doesn't properly support G31 moves.
    G31 are supposed to set a system var with the trip point. This var is used to set Z zero. Most chinese motion controllers don't set the var, so the zero point is not set correctly.
  18. #1318
    May 2005
    32
    Well it works, manily. Every once in a while it seems to glitch. We actually wrote down our step by step procedure to eliminate procedure as a cause. I could tell when the value was wrong after doing a regen toolpath, after zering the axis's. Mach reads through the G-code and they flash on the DRO, when it's right 1.8" inches flashes in the z-axis DRO, when it's wrong 3.8" flashs there. I hope you are understanding what I'm trying to say? We also intermittently get out of sync errors reported.
    Could anyone recommend a reliable replacement for that chinese motion board?
  19. #1319
    Anything not made in China.
    The Ethernet Smoothstepper is probably the most popular. All of the CNC Drive controllers are very good.
  20. #1320
    May 2005
    32
    I was looking at this one.
    UC300ETH-5LPT ethernet motion controller for Mach3
    I'm guessing, judging by the amount of views, this is the one you're talking about.
    CNC Ethernet SmoothStepper for Mach3 / Mach 4 CNC Smooth Stepper Motion Control
    I'll have to read through the documentation on them and the stepper drivers we have (chinese drivers as well)
    Thanks for all your help ger21, at least it's useable (hopefully) until I can get too doing some replacements.
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
