586,103 active members*
3,908 visitors online*
Page 9 of 76 78910111959
Results 161 to 180 of 1506
  1. #161
    Jan 2008
    241
    I got this error a couple days ago(never had time to upload it till now)
    Art Code: 9991
    The code was still running while displaying the error, till I hit my limit switch! Doh!
    Once I had to interact with Mach3, everything went to ..... well you know!
    Only way to correct it was a reload of the software...
    First time I ever got an error code....
    Is this the error your refering to Gerry?
    I have the latest Ver of Mach3.
    Chris
    P.S. Hey Gerry, THANK YOU for an AWESOME SCREENSET!! :cheers:
  2. #162
    That's an internal Mach3 error, not related to the screen. From what I've read, it doesn't really tell you what the problem actually is.
    How many lines of code is that. With very long g-code programs, it might be a good idea to turn off the toolpath display. This is due to the way Mach3 displays the toolpaths. It uses a lot of resources. That could have caused the error. Again, it's not elated to any particular screen.
    Were you trying to use the MDI while g-code was running? It looks like it??
    The error I mentioned earlier that someone else had, was their machine would crash into the home switch, when it should have been impossible, based on the error messages they were seeing from the macro.
  3. #163
    Feb 2009
    499
    How goes the expanded probing screen? Not urgent, just curious. Thanks,
    "72.6 per cent of all statistics are made up on the spot." - Steven Wright
  4. #164
    Sorry, been really busy lately. I'm working on a revised version right now, and won't release it without the probing.
    I'm adding a button to zero XY to a laser crosshair. Offset distances will have to be set in a macro, because there's no room for 2 more DRO's. But it's not something that would need to be changed.
    And also adding an option to ignore the M6, useful if you have code with an M6, but no toolchanges.
  5. #165
    Jul 2009
    272
    I smell royalty checks coming
    Gerry look at link in my signature below..........
    Thank you for your support in developing better cnc experiance.
    Scan my avatar with smart pnone ...... http://www.big-tex.tk/
  6. #166
    May 2009
    435
    Someone on the Mach support forum asked why there wasn't a screen that looked like a "Windows" program, so I decided to see if I could make one. Been working on it on and off for a few months, but started over from scratch today. Here's a little preview. It's only going to have one screen + the flyout.
    Edit - 1/1/11
    This screen is now available for purchase at
    The CNC Woodworker - Mach3 2010
    ** Edit: Issue resolved
    I have downloaded this screenset and I can't wait to start using it!
  7. #167
    Dec 2006
    259
    Hi Gerry,
    I haven't been following this thread for a little while, and still intend to eventually purchase this screenset. Did I catch that you're doing a probing operation in there somewhere also? Will it work with a probe to sense the edge of a fixture to establish x=0 and y=0 at the fixture corner, or will it only work with a laser over a hole?
    I'll do well to afford a regular touchprobe, but a laser might be a tad out of my budget.
    Don Williams
  8. #168
    Feb 2009
    1290
    I'm using Gerry's screen with a generic old touch plate. I do not think he supports the x0, y0 probing yet but I think he is working on it.
  9. #169
    I'm working on it Don, but haven't released it yet. Yes, it should work with a probe just fine.
    As for the laser crosshairs, I think they are less than $10 on Ebay.
    5mW Focusing Laser Module with Dot or Crosshair Beam - eBay (item 150548667519 end time Mar-15-11 06:28:10 PDT)
  10. #170
    CNC Lurker, I sent you a PM, since you apparently didn't receive the 5 emails I sent you. We'll get this straightened out today.
  11. #171
    Dec 2006
    259
    Well, that's affordable... I'm just not sure how I would use it with a wood router. Looks like I'll have to do some research.
  12. #172
    May 2009
    435
    Thank you very much, I've pm'ed you my gmail email account.
    It is a very beautiful screenset, thanks for the time you've spent making it.
  13. #173
    Jul 2009
    272
    Quote Originally Posted by DonW View Post
    Hi Gerry,
    Don Williams
    My screen set still has center x y zero based on probing, entire routine Garry is using for tool zeroing was initially written by me and refined by me as well, his screen set is using it in different way, as m6end. Tool zeroing is next best thing to sliced bread.......
  14. #174
    entire routine Gerry is using for tool zeroing was initially written by me and refined by me as well,
    Actually, only about 1/2 of the code I use is based on yours, and I modified most of that. Mine has more options, and more safety checks to prevent tool and machine crashes.
    I based mine on PoppaBear's revision of your code, which is about 150 lines. Mine is almost 300 lines of code.
    Myself and MikeF spent over two weeks (of daily testing) modifying, adding to, and testing the code I use.
  15. #175
    Dec 2006
    259
    Quote Originally Posted by Big-tex View Post
    ...Tool zeroing is next best thing to sliced bread.......
    Can't argue with that...especially after I crashed the Z axis into the X limit. Nothing is ever quite located the same after that.
  16. #176
    May 2009
    435
    I posted this in my build thread, but I'm stuck because I haven't gotten a reply. Since you guys have wired the auto-zero, can you tell me if the illustration in this post is correct because I would hate to fry my Gecko:
    Auto-zero wiring question LINK
    (Sorry for cross-posting, but I need direction so I can move forward).
  17. #177
    May 2005
    925
    What I did when I made my autozero is to have the touch probe PIN with a weak pull up (10K resistor to +5v) so when the machine touched the plate it would read as GND (zero) no need for extra cables or clips. Good Luck
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
  18. #178
    Paul, I don't have a g540 so can't help much. But, I have my spindle wired to ground (it's grounded through the AC power cord), so if you're spindle is grounded, you probably shouldn't connect the input pin to the spindle. I have my input connected to the plate, with pull up resistors. Not sure if you need the pull ups with the G540.
  19. #179
    May 2009
    435
    Thanks, I'll be connecting the wired plate to pin 4, then touch the router bit to make sure the light comes on in Mach.
    I don't know anything about pull up resistors or if I'll need it or not.
  20. #180
    May 2005
    925
    Gerry one question, is it possible to add a LED to each axis to show when its selected when MPG is used? I modified the standard mach3 screen to do this as it a great visual aid when you use an MPG remote, because if you are looking at the piece and the screen you don't need to look also to the remote axis selector. Just an idea.
    Pablo (soon to be customer)
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
