586,075 active members*
4,283 visitors online*
    Jul 2010
    Mach 3 scaling issue? not sure if its machine.
    hey.. waiting for my machine to get fixed buy i noticed something odd happening when i import g-code into the Mach3 on this machine... everything is almost double scale... not the normal 10x scale from mm to inches, but a smaller almost doubling. If i manually move the X axis in the co-ordinates window from zero inches to +1 inches, that plus 1 inch measures out to 1.3 inches with my calipers.
    If i take the same mach3 gcode file and load it into another machine here, the scale is perfect, so the problem seems to be just the way this machine is configured ( from the factory )
    any ideas?
    Mar 2008
    195
    I have run into the same situation. Between my 3 computers running Mach3, each one has different (steps per inch) settings under motor tuning for the same cnc machine.
    I have always wondered about that since backing up my mach settings for the motor tuning won't apply on another pc.
    Jul 2010
    so do i screw around with the steps per inch settings to fix it?
    Mar 2008
    195
    Quote Originally Posted by CNCwilson View Post
    I had to calibrate each axis "steps per inch" on each one of my computers. The settings turned out different on each one of them. I also had a spare harddrive that I setup to use on one of the computers just in case the original harddrive died and I had to do the same thing there.
    I am curious to know if this situation has occurred to others. I may post this question on the mach support forum to see if an answer is already available or can be found...
  1. NM-145 Mach 3 Gcode scaling error?
    By CNCwilson in forum Novakon
    Last Post: 03-03-2011, 04:30 AM
  2. Mach 3 homing issue.
    By evo4wrx in forum CNC Machine Related Electronics
    Last Post: 07-10-2010, 03:04 PM
  3. MACH 3 FREEZE ISSUE XP pro 02
    By carbidecraters in forum Mach Software (ArtSoft software)
    Last Post: 02-25-2010, 07:49 PM
  4. Mach issue with my mill
    By Rich05 in forum Mach Software (ArtSoft software)
    Last Post: 12-01-2008, 12:00 AM
  5. Scaling Issue
    By obie1 in forum Hobby Discussion
    Last Post: 10-10-2004, 12:57 PM
