586,121 active members*
3,721 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc OT on 1995 Daewoo Puma 8s Lathe
    Jan 2010
    18
    Bought machine May 2009 and battery problem dumped all parameters shortly thereafter. Reloaded parameters that came with machine, but had to tweek several to just get it working. Been doing turning work only, never needed to thread until recently. *problem* thread pitch will not repeat. Position Coder is brand new from Fanuc last week. Think it must be a parameter problem but have exhausted all efforts to correct ourself. Anyone please help make suggestion of possible problem or changes we can try! Thanks! Also since parameters were lost RPM display on control station does not work. RPM only reads zero. Thanks!
    Feb 2006
    992
    Do you notice the RPM change while thread? some control very picky about that, need to stay constant.
    The best way to learn is trial error.
    Feb 2006
    1792
    If rpm display is always zero, possibly there is no feedback from spindle.
    Double check parameters 6500 - 6520, 0002 & 0028
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
  1. Daewoo Puma 400 Lathe
    By TURNER in forum Daewoo/Doosan
    Last Post: 08-23-2012, 02:16 PM
  2. Daewoo Puma 700 LM lathe
    By Norboy in forum Daewoo/Doosan
    Last Post: 07-10-2008, 06:35 PM
  3. Daewoo Puma 700 LM - Lathe
    By Kim in forum Daewoo/Doosan
    Last Post: 04-18-2008, 07:18 PM
  4. NEED HELP with Fanuc OT on Daewoo Puma 6 lathe
    By Michael Esch in forum Fanuc
    Last Post: 02-21-2008, 12:54 AM
  5. daewoo puma 450 lathe
    By gokulkavin in forum Daewoo/Doosan
    Last Post: 04-07-2005, 12:18 PM
