I hate to post 3-rd question in the row but I promise it is going to the last one
I need to machine a surface of the Ionic column which is fluted along the shaft and ending with scallops. I have tried 5-axis Multisurf but it failed due to complexity of the surface. Rotating the actual stock on the table would be difficult as it would require special jig. So I am thinking to try to rotate WCS to position my stock that I could use 3-axis surface machining. Will that work? Will my 5-axis router rotate the A and B-axis to apropriate angle and machine my 3-axis code? I admit that I never tried this before and reading help is not that clear as I wish.
Joe
