586,263 active members*
3,807 visitors online*
IndustryArena Forum > CAM Software > Mastercam > construction plane and view
    Feb 2010
    i have a new Mazak 630 2T Variaxis with a trunion table (mill/turn)
    im trying to get the correct construction plane and geometry view settings in mastercam x4 -to turn at -90. in EIA. the usual turning application for lathe in Gview AND Cplane is TOP
    Now, when table orientates to -90 the machine coordinate system will be that of
    z
    Y<
    now, in eia i have to incorporate the usual G18.2 along with
    G10.9 x1(selection of diameter input for X axis) if your values post out diametrically in the X value (i have proved this out in "A" 0 turning)
    but the machine coordinate is like explained above
    (tools will move in the "Y" & "Z" axis)
    Has anyone experienced this application?
    thanks
    Mike
    Mar 2005
    988
    Do you have a mill/turn post? Are you writing the mill and turn on seperate files?
    Unless you have a mill/turn post, MD, CD (or can write one), this could be challenging trying to do in the same file
    If you're only trying to get the turn work through posting, this might now be that bad. If you're only on a Lathe seat, would be just a matter of writing the "A-90." as a hard code or through the use of switches built in MI/MR.
    Might be able to get it recognize A angle by toolplanes but again, I'm thinking that a lathe post may not support that.
    It's just a part..... cutter still goes round and round....
    Mar 2006
    1013
    Trunion Table on a Lathe?
    Something doesn't sound right.
    If it's a lathe, you have to move it into the correct orientation. You can use WCS to flip the part for a proper lathe orientation.
    Lots of good multi axis lathe stuff in here.
    http://www.tipsforcadcam.com/store/2...uct/TFM-CDL2-X
    and there's a combo package that covers Lathe, from start to finish.
    http://www.tipsforcadcam.com/product...D-LatheCombo-X
    It even has a generic mulit-axis lathe post included.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    Dec 2013
    10
    The construction plane must be effective. To do this, you must open the contextual menu of the construction plane node and choose or make a double click on this node. It appears on a grey background in the tree view. An unique building plane can be active in a project. Activating a new construction plane, deactivates the old effective construction plane.
    Thanks!
    Construction and Earthmoving Machinery Online
    Victoryequipment
  1. HOW TO SET X AND Y AS TOP VIEW
    By atlantic23 in forum Solidworks
    Last Post: 06-02-2009, 12:11 AM
  2. What happened 3D construction plane?
    By Gary Campbell in forum Mastercam
    Last Post: 03-03-2008, 03:18 PM
  3. help in construction!
    By drumbuilder in forum Wood Lathes / Mills
    Last Post: 01-28-2008, 02:43 PM
  4. construction plane and tool plane
    By nervis1 in forum Mastercam
    Last Post: 11-05-2004, 06:53 AM
  5. cycles initial plane/retract plane
    By HuFlungDung in forum OneCNC
    Last Post: 06-27-2003, 01:02 AM
