586,119 active members*
3,325 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 078 NUMBER NOT FOUND with M100 ON FANUC 18M
Page 1 of 2 12
Results 1 to 20 of 28
    Jul 2010
    Question 078 NUMBER NOT FOUND with M100 ON FANUC 18M
    Hello everyone!
    I am Nguyen from Vietnam. Who can help me repair some problems? My CNC’s serial is Fanuc 18M. (Anderson Industrial Corp)
    Machine Type: NC-2525TC2+G/PT
    Machine Number: FAANCPT92077
    I have machine’s parameter. The last time, machine had an error 915 SRAM PARITY and I repaired it. But after, when I write M100 (Call subprogram waiting) then “078 NUMBER NOT FOUND” message on screen. I can not use M100 code.
    M00, M01, M02, M03, M11, M12…. M98, M99... OK. Problem with M100 code.
    0078 NUMBER NOT FOUND on help menu description:
    “Function: Subprogram call
    Alarm: the program number or sequence number designated by P in block M98, M99, M65, and M66 cannot be found. Or sequence number designated by goto cannot be found.”
    What can I do now? Can you help me?
    And I need file post processor for CNC FANUC Oi-TC in AlphaCAM, who can share for me?
    Thank you very much!
    Jan 2007
    333
    Possibly when you repaired the SRAM you lost parameters and the option parameter for subprograms was not turned back on. I do not know which parameter that is.
    Hope this helps.
    Feb 2006
    1792
    I have not seen the use of M100. What does it do? Possibly it is machine specific.
    If M98/M198/G65/G66 are working, it should be enough.
    2932
    Maybe M100 is an macro or subprogram call, and the program it's calling is no longer in memory?
    Check parameters 6050-6059, and 6080-6089 to see if one of them = 100.
    6050 > O9010
    6059 > O9019
    6080 > O9020
    6089 > O9029
    Jul 2010
    Thank you dcoupar, sinha_nsit and bborb
    I will check parameter. M100 is a macro. I use it for subprogram.
    M100 call subprogram. I write a program when use M100 follow:
    O7000 (MAIN PROGRAM);
    M100;
    IF [#1102 EQ 1] GOTO1000;
    M98 Pxxxx (PROGRAM FOR Y TABLE);
    M99;
    N1000;
    M98 Pxxxx (PROGRAM FOR V TABLE);
    M99;
    that is M100 in my program, i dont know to repair this problem. Sometime i use this code on top program when i do on a table to wait ready button. M100 is a macro line. If i use it, i can do auto. We work on 2 table and program run if one of 2 tables ready.
    I will check parameter 6050-6089 and tell you later
    Thanks alot
    Apr 2008
    49
    Do you have pallet changer on that machine?, that #1102 must be for checking pallet or table number. Can you post last few lines of sub Pxxxx.
    Feb 2006
    1792
    Quote Originally Posted by dcoupar View Post
    This is the only possibility.
    If he is not sure what the macro/subprogram called by M100 is supposed to do, he possibly does not need to use M100.
    Jul 2010
    i just check parameter, do you know to modify the PLC? What can i do now?
    PARAMETER (CUSTOM MACRO)
    6030 SUB CALL (FLPY) 0
    6031 0
    6032 0
    6033 0
    6034 0
    6035 0
    6036 0
    6037 0
    6050 MACRO CALL G 0
    6051 0
    6052 0
    6053 0
    6054 0
    6055 0
    6056 0
    6057 0
    6058 0
    6059 0
    6071 SUB CALL M 100
    6072 101
    6073 0
    6074 0
    6075 0
    6076 0
    6077 0
    6078 0
    6079 0
    6080 MACRO CALL M 0
    6081 0
    6082 0
    6083 0
    6084 0
    6085 0
    6086 0
    6088 0
    6089 0
    6090 SUB CALL ASCII 0
    6091 0
    6092 0
    2932
    M100 is calling program O9001 - is this program stored in memory? If not, M100 will cause alarm 078.
    M101 is calling program O9002 - is this program stored in memory? If not, M101 will cause alarm 078.
    Jul 2010
    Hi Dcoupar,
    Can you show me about that program? 9001 and 9002. My memory is empty.
    2932
    Your 9000 programs may be hidden? Check parameter 3202 bit 4. If it's 1, then the 9000 programs are locked. Change it to 0 and see if programs O9001 and O9002 are in the memory.
    What should M100 and M101 do on your machine?
    Jul 2010
    Dear Dcoupar,
    M100 and M101 use to call subprogram. That code on the top of program. When use it, it wait we push OK button on the table then machine will run. Repeat program until finish item i want to do. (999999999 times ok)
    Apr 2010
    89
    Need Help! 078 NUMBER NOT FOUND with M100 ON FANUC 18M
    Hi Nguyen,
    O9001 macro should be the tool change macro which is normally called with M06,
    Parameter #7071 is the M code used to call macro program O9001
    O9002 macro should be the pallet change macro which is normally called with M60,
    Parameter #7072 is the M code used to call macro program O9002
    Macro Programs O9001 & O9002 must be in your machines memory.
    Do you have a backup copy of your machines macro's that you can reload into the machine.
    Jul 2010
    Hi Frank,
    My CNC change tool Ok. It has two spindles and change tool by ATC arm. M06 enable vacuum for Y table, M07 disable vacuum for Y table. M08, M09 for V table. M05 change tool for two spindle. M51 change tool spindle number one. M53 change tool spindle number 3. I think O9001 is a system program, when i format the RAM and upload data then disable this program i will test to enable it on parameter 3202 bit 4. Tell you later. Thank you.
    Jul 2010
    hi all,
    I checked parameter 3202 and change bit 4 to 0. But have not O9001 in my memory. Can you show me how to write this program? Can i get it?
    Thank you very much.
    M00: STOP, M01: STOP, M02: STOP, M05: CHANGE TOOL(2 SPINDLES), M06: ENABLE VACUUM NUMBER1 TABLE, M07: DISABLE VACUUM M06, M08: ENABLE VACUUM NUMBER2 TABLE, M09: DISABLE M08, M11: SPINDLE 1 DOWN, M12: SP1 UP, M13: SP1 ROTATE CW, M14: CCW, M15: TURN OFF SP1, M21: SPINDLE 2 DOWN, M22: UP, M23: ROTATE, M25: SP2 TURN OFF (NUMBER2 IS A SAW). M30: FINISH PROGRAM, M31: SPINDLE 3 DOWN, M32:UP, M33: ROTATE CW, M34: CCW, M35: TURN OFF SP3, M40: Y&V OPERATION NORMAL, M50 AND M60 (FOR M100), M51: CHANGE TOOL NUMBER1, M53: CHANGE TOOL NUMBER2, M56: ENABLE PIN 1 AREA, M57: DISABLE M56, M71: SP1&SP3 DOWN, M72: UP, M73: ROTATE CW, M74: ROTATE CCW, M75: TURN OFF, M92: ALL SPINDLE UP, M95: ALL SPINDLE OFF, M98: CALL SUBPROGRAM, M99: FINISH SUBPROGRAM (REPEAT).
    Feb 2006
    1792
    Why do you insist on using M100? The program it is referring to appears to have somehow got deleted from your machine. Nobody can write it for you because others do not know what it was doing. So, use M98/G65 for calling subprogram/macro. Analyze your list of M-codes on your machine, and command as required.
    2932
    I would suggest you contact the builder and ask if they can supply the O9001 & O9002 programs.
    [email protected]
    Jul 2010
    Hi all,
    I had some e-mails to Anderson but them do not help me this problem by e-mail. I waited a long time for this, i think we call them to our company to pay some fee
    Jan 2010
    99
    using your machines custom M-codes from the list you posted, and standard g-codes, figure out what sequence of MDI codes will successfully complete a tool change... then i can tell you how to turn that into the proper macro
    without being in front of the machine is tough to write from scratch, and more importantly debug... but knowing that MDI sequence will usually be enough
    typically its sequence will be:
    home necessary axis', orient spindle, kill coolant
    step thru machines tool change cycle (swing arm, umbrella, turret, etc) using internal m-codes (m50s and m70s often) and t-code
    - gwarble
    Apr 2010
    89
    Quote Originally Posted by dung_ninhbinh View Post
    Hi Nguyen,
    Is M100 used to call a subprogram which checks which Table is setup and ready to be machined.
    On our twin pallet machine when the operator has finished setting up the job on the pallet not being used by the machine the 'Setup' button needs to be activated so the machine knows it can change pallets and carry on machining on the new pallet.
    This is controlled in our pallet change macro O9002 by user input #1020, if #1020=1 pallet is setup, if #1020=0 machine waits till pallet setup button has been pushed before continuing.
    N30 IF[#1020 NE1]GOTO30 (Loops until setup button pushed).
    It's possible M100 only calls a subprogram which checks if a table is ready to be machined by checking which tables vacuum is enabled (only a thought).
    It would then be a matter of checking user inputs/outputs in the PMC to see which variables are used for function checks and then writing a subprogram
    to do these checks and associate M100 to call this subprogram.
    Hope this helps,
    Frank.
    Below is a list of User Inputs/Outputs from our machine that might give you a hint on what to look for.
    DAEWOO ACE H-100 USER DATA INPUTS.
    G051.0 UI00.G #1000 APC MACRO START/FINISH
    G051.1 UI01.G #1001
    G051.2 UI02.G #1002 PALLET ON B AXIS
    G051.3 UI03.G #1003 PALLET #1 ON CHANGE TABLE
    G051.4 UI04.G #1004 PALLET #2 ON CHANGE TABLE
    G051.5 UI05.G #1005
    G051.6 UI06.G #1006 B AXIS SECOND REF POINT RETURN IN POSITION
    G051.7 UI07.G #1007 MACHINE LOCK SWITCH
    G050.0 UI08.G #1008 AUX FUNCTION LOCK SWITCH
    G050.1 UI09.G #1009 REPEAT SWITCH
    G050.2 UI10.G #1010 ATC TOOL CHANGE SECOND REF POINT RETURN IN POSITION
    G050.3 UI11.G #1011 APC REF POINT RETURN IN POSITION CHECK
    G050.4 UI12.G #1012 APC CHANGER 1/5 SELECT
    G050.5 UI13.G #1013 APC NOT INITIAL CHECK
    G050.6 UI14.G #1014
    G050.7 UI15.G #1015
    G049.0 UI16.G #1016 AUTO B AXIS CLAMP/UNCLAMP SELECT
    G049.1 UI17.G #1017 360 ROTATE B AXIS SAME COMMAND
    G049.2 UI18.G #1018 360 ROTATE B AXIS CCW DIRECTION
    G049.3 UI19.G #1019 ATC MACRO START/FINISH
    G049.4 UI20.G #1020 SETUP BUTTON CHECK
    G049.5 UI21.G #1021
    G049.6 UI22.G #1022
    G049.7 UI23.G #1023
    G048.0 UI24.G #1024
    G048.1 UI25.G #1025
    G048.2 UI26.G #1026
    G048.3 UI27.G #1027
    G048.4 UI28.G #1028
    G048.5 UI29.G #1029
    G048.6 UI30.G #1030
    G048.7 UI31.G #1031
    DAEWOO ACE H-100 USER DATA OUTPUTS.
    F051.0 UO00.G #1100 APC MACRO START
    F051.1 UO01.G #1101 APC MACRO START
    F051.2 UO02.G #1102
    F051.3 UO03.G #1103 AXIS APC POSITION/APC POSITION
    F051.4 UO04.G #1104
    F051.5 UO05.G #1105
    F051.6 UO06.G #1106
    F051.7 UO07.G #1107
    F050.0 UO08.G #1108
    F050.1 UO09.G #1109
    F050.2 UO10.G #1110
    F050.3 UO11.G #1111
    F050.4 UO12.G #1112
    F050.5 UO13.G #1113
    F050.6 UO14.G #1114
    F050.7 UO15.G #1115
    F049.0 UO16.G #1116
    F049.1 UO17.G #1117
    F049.2 UO18.G #1118 ATC MACRO END/ATC MACRO START
    F049.3 UO19.G #1119 ATC MACRO START
    F049.4 UO20.G #1120 PALLET SETUP BUTTON CANCEL AUX
    F049.5 UO21.G #1121
    F049.6 UO22.G #1122
    F049.7 UO23.G #1123
    F048.0 UO24.G #1124
    F048.1 UO25.G #1125
    F048.2 UO26.G #1126
    F048.3 UO27.G #1127
    F048.4 UO28.G #1128
    F048.5 UO29.G #1129
    F048.6 UO30.G #1130
    F048.7 UO31.G #1131
Page 1 of 2 12
  1. Fanuc 0M number and dripfeed?
    By jeppes in forum Fanuc
    Last Post: 07-12-2023, 05:15 AM
  2. Fanuc Part Number/Revisions
    By botts_ in forum Fanuc
    Last Post: 07-27-2009, 05:10 PM
  3. 078 alarm (number not found)
    By jorgehrr in forum Parametric Programing
    Last Post: 06-23-2008, 07:57 PM
  4. 078 alarm (number not found)
    Last Post: 06-12-2008, 08:12 PM
  5. Replies: 1
    Last Post: 08-22-2007, 06:39 PM
