586,075 active members*
4,256 visitors online*
    Aug 2009
    899
    Simple but how?
    I need to move geometry from one level to another in X3, but how can I remove it from one level and put it on another? I am working on a multi-part project and some of the parts were drawn on the wrong levels.
    Jul 2010
    Moving Geo
    Not 100% sure on X3 but on X2 select the geometry that you want to move and then left click on the level drop down menu. A box will come up saying move or copy and then you can select the level. This is how you can change the color and line style of something. Like I said it works on X2 not sure about x3
    Mar 2005
    988
    Look on the bottom of your screen and you'll see a 'Level' button. A couple ways to do this....
    You could first select the geometry you want to move. Then right click the "Level" button and a menu will pop up. Just follow the prompts... (the usual... COPY/MOVE, level select, naming, etc)
    ... or go through the drop down menus...
    It's just a part..... cutter still goes round and round....
    Aug 2009
    899
    Awesome it works, thanks
    Dec 2008
    3109
    [QUOTE=psychomill;800311]Look on the bottom of your screen and you'll see a 'Level' button. A couple ways to do this....
    QUOTE]
    Or you can do it the other way round
    R-click the required operation to start the proceedure, select the entities, then accept to complete ( lower toolbar )
    another aid is :-
    R-click on a lot of mastercam items can lock it ON for constant use when inside a command
    ie L-click on the arc centre is a one-shot go,
    but do a R-click on arc centre and it's on for the rest of that command
    R-click or L-click on the QM icons works the same way too
  1. Simple Calculations for a simple mind.
    By cr8zy1van in forum Mechanical Calculations/Engineering Design
    Last Post: 11-04-2009, 10:12 PM
  2. It is something simple I'm sure..but????
    By cuttingedgepart in forum Tormach Personal CNC Mill
    Last Post: 09-14-2009, 12:55 PM
  3. simple use for the cnc
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 03-07-2009, 02:49 AM
  4. Please Help!! Simple 3-D part not so simple for me
    By eaglegage in forum Mastercam
    Last Post: 05-15-2008, 04:00 PM
  5. Simple Question Simple Answer ?
    By p3t3rv in forum Stepper Motors / Drives
    Last Post: 02-16-2006, 04:00 PM
