586,590 active members*
2,545 visitors online*
    Jan 2007
    66
    I-80 drip feed
    I need help drip feeding to a Yasnac I80. I've tried out some demo DNC programs. So far they all seem to be very similar. I can send and receive programs and parameters with all the programs and hyper terminal. I have hooked a cable from the SMON FC200 db9 through a Radio Shack Null modem adapter without handshaking to my PC. Right now I'm using a cable from the CN27 db25 port to the PC. I tried to follow the diagram on page 55 of http://www.yaskawa.com/site/dmcontrol.nsf/%28DocID%29/TKUR-5EKMAD/$File/TOE-C843-11.5.PDF
    Kevin
    Jan 2007
    66
    I think I figured it out. Switched to tape. Hit start. Started sending with DNC. When the buffer filled, it stopped sending and waited for ready signal from the Yasnac. I'll post if I have any more questions.
    Kevin
  1. DNC-B to use drip feed
    By 78nova in forum Okuma
    Last Post: 02-02-2010, 08:21 AM
  2. Drip feed on/off
    By sve0019 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-14-2009, 05:14 PM
  3. Drip feed?
    By MrWild in forum Dolphin CAD/CAM
    Last Post: 02-25-2008, 05:33 AM
  4. BMC-20 w/Max II drip feed......
    By GPena in forum HURCO
    Last Post: 10-31-2007, 06:37 PM
  5. Drip Feed
    By camtd in forum Surfcam
    Last Post: 08-01-2006, 12:09 AM
