Look at the drawing, the X beams are in
RED, I'm not sure about the best design for a rigid table that'll act like a big torsion box.
What do you mean when you say "The tolerances for the HEB list +/- 0.5mm for the width of the dimension" do you really mean the HEB100 beams are 100mm +/- 0.5mm wide & high ? so it won't be able to draw a "perfect" strait line ?
If it's really the case & if the width or height of the beam vary along the length, I have no idea on how to work it out
a 3m 60Kg beam won't be easy to machine or grind to the required tolerances.
Other questions arise, is 0.5mm acceptable for wood/Al/marble working/carving what's the accuracy of the chain drive, 0.5mm seems to be big especially for small/fine carvings.
What kind of accuracy/tolerances are you guys happy with, what can a mechmate achieve ?
Thanks !
cnc2.
