To me this means that it is the belt which drives the stepper motor & it sounds weird because in fact it is the motor which actually drives the belt....am I wrong ? (English is not my native language so, explain please)
My apologies to you. I guess I did say that wrong. The steppers are using belts to drive the machine through a transmission that also uses belts and gears.
Thanks for the input ! that sounds interesting for an accuracy/repeatability, I shouldn't need more that that
OK but is your machine belt driven or does it use rack & pinions with belt reduction on the steppers ? Any pics/vids ?
My machine uses rack and pinion but the belt driven transmission with stepper is what gives the motion
Thanks for the info on CNCBRAIN, looking at the electronics hardware it uses, it won't be a DIY project, most of us will need to buy it ready for use, since the assembly/soldering of the used components require skills & tools unavailable to the average DIY builder. Will cnc brain be affordable to us ?
The Brain is suppose to be ready to hook up and run once you get it, and the cost is projected to be around $500 US
Same here, I can't afford linear scales(long encoders), but I thought about replacing them by a cheap rotary encoder connected to a toothed pulley which rolls on a fixed toothed belt just for tracking purpose, if the belt is accurate, then, if the circumference of the pulley is around 6cm, a resolution of 60/256=~0.2mm can be reached with a 256 CPR encoder (each turn of the pulley (60mm) will be divided into 256 steps or more with a higher resolution encoder)
I am going to try the strain/force feedback first to find out if it does work, and if so, I will then set up a very accurate index point for the machine to have for reference. If these do not work to my satisfaction, I intend to build my own long encoders using magnetic feedback
Thanks !
cnc2.
