586,077 active members*
3,591 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > LNC 8 servo and LDU alarms
Results 1 to 6 of 6
    66
    I bought an LNC8 lathe that had a servo drive issue. Was getting X-axis alarms when at the other shop. After moving it into my shop I am getting a LDU overload alarm #113. Are these alarms related of do I have something else going on? I cannot find where to reset and it comes on as soon as the screen loads. This is a 1994 with 5020 control.
    Scott
    Mar 2009
    1982
    try power on with emergency stop activated.
    Is the LDU alarm of X axis also?
    What indication on drive units, power supply unit inside the control cabinet?
    66
    The alarm message is:
    Alarm-A #113 LDU overload 1
    When I first started-up the machine the X-axis motor was making some noise for about 15 sec. then the alarm came on. Now when I turn the power on all I get is the alarm. At the other shop I was getting an X-axis alarm it would reset and the x-axis motor would produce a high pitched whine for about 10 sec then shutdown and get a x-axis alarm. We switched the X-axis and Z-axis wires from the drive and the fault followed to the Z. I have tried pushing the E-stop and resetting but have not tried power-up with E-stop pushed.
    Scott
    Feb 2009
    6028
    Sounds like a bad drive unit. I've tried to get Okuma drives repaired, but never got one to actually work. Maybe someone else will chime in with a good alternative, since Okuma does not support those drives any longer.
    Mar 2009
    1982
    Okuma Europe, Okuma Japan offers replacement drive units.
    It's a lot of possibilities to repair. Some companies in Malaysia, Philipines, USA, offer repair and do good job.
    It's not absolutely bad drive unit, maybe just circuit breaker is tripped.
    66
    I have a guy that can repair the drive, but he would like for me to do some troubleshooting while the drive is in the machine. At the other shop I was not getting the LDU overload and the troubleshooting would have been better there. I would like to clear the LDU overload to try and do a better job at troubleshooting. When I first powered the machine at my shop, the drive sent power to the servo's for a few seconds like it did at the other shop. Now all I get at power-up is the LDU overload. It seems that I need to figure out how to reset it to get some time to troubleshoot the drive.
    Scott
  1. Fanuc Servo Alarms 401, 414, 424
    By sushrut in forum Fanuc
    Last Post: 10-20-2013, 09:31 PM
  2. alarms
    By kling8 in forum Fadal
    Last Post: 10-27-2009, 04:22 PM
  3. ALARMS ALARMS ALARMS
    By tunitime in forum Okuma
    Last Post: 08-05-2009, 05:37 PM
  4. Fanuc 0t servo alarms
    By p1etaster in forum Fanuc
    Last Post: 11-05-2008, 09:26 PM
  5. M Plus Alarms
    By MJMark in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-29-2008, 09:39 PM
