586,108 active members*
3,084 visitors online*
IndustryArena Forum > CAM Software > Mastercam > MCX4 - toolpaths crossing each other while contouring?
    Jun 2010
    60
    Unhappy MCX4 - toolpaths crossing each other while contouring?
    Hi all
    I want to cut a 2D contour toolpath in a very specific way. This unfortunately means the contour lines have to cross over each other.
    I'm driving the center of the cutter with 'compensation type - off'
    MCX4 takes the short cut. Is there a way/setting to make MC follow the profile as I have selected it?
    The line end points are not at the intersection!
    Thanks in advance
    Craig
    Feb 2006
    992
    Manual chain will let you do that.
    The best way to learn is trial error.
    Dec 2008
    3109
    turn OFF the gouge checking, but also check the toolpath thoroughly that it is doing what you want it to do
    PS, I may be incorrect, it should read "turn OFF the look ahead" , this allows a toolpath to cross itself like trying to trace the figure 8 without lifting
    Jun 2010
    60
    Quote Originally Posted by CNCRim View Post
    How do you manually select a chain that has no branch points?
    I can't seem to find a way of deactivating the chaining.
  1. Replies: 2
    Last Post: 06-14-2010, 07:19 PM
  2. How to detect Kerf Crossing ? [ THC PLASMA ]
    By MaXx in forum CNC Machine Related Electronics
    Last Post: 12-02-2008, 10:54 AM
  3. Crossing to the parallel universe.
    By ynneb in forum LinuxCNC (formerly EMC2)
    Last Post: 08-05-2008, 02:30 PM
  4. 3D Contouring????????
    By cut2spec in forum Benchtop Machines
    Last Post: 03-18-2007, 07:08 PM
  5. contouring help
    By rbest27 in forum Surfcam
    Last Post: 02-02-2007, 04:14 PM
