586,094 active members*
4,000 visitors online*
    Jul 2010
    Need help on Fanuc OI-td series control
    I just getting familiar with this control as it is a much newer model then what i am used to. I wrote a program to flex a piece of steel but when i try to tell it to use a the G71 canned cycle the machine doesn't understand and try's to take it all in one cut. does anyone know how to canned cycle an undercut on this control?
    EG:
    it starts at an OD of 11.25" and about 11.5" from the face of the piece. This is what i need it to canned cycle: i need it to plunge down at a 15 degree angle into a 20" radius to and OD of 7.5 and continue straight for 122" then into a 10" radius into a 15 degree angle back out to an OD of 9.5.
    As far as my knowledge goes it should b able to be done with a G71. is there a parameter that i need to change or is there a different command for it?
    thanks
    Jul 2010
    118
    you would need to activate G71 type 2 for profile undercut, by program both axis in the first line, e.g. (this is a mm program)
    G0 X150 Z6
    G71 U4.0 R1.0
    G71 P2 Q3 U-2.4 W.1 F.32
    N2 G0 X 100 Z4
    N3 X145 Z-40
    Jul 2010
    Thank you very much funny thing is inhad time to sit down and go through all the manuals for the machine and figured it out. It just took me a bit tonfigure out such of the 6 manuals to look in and then decipher the overly technical language lol. Thanks any ways big help
  1. Replies: 5
    Last Post: 05-31-2019, 05:16 PM
  2. Fanuc Series O-MD Control
    By dcskid in forum Fanuc
    Last Post: 03-26-2009, 12:22 PM
  3. X geometry in fanuc series O-TT control
    By cuz1007 in forum G-Code Programing
    Last Post: 03-15-2009, 12:40 AM
  4. Series 0 control
    By ajm100a in forum Fanuc
    Last Post: 08-25-2008, 11:12 PM
  5. Fanuc axis drive control PCB- S Series
    By M.RISHIKESH in forum Fanuc
    Last Post: 12-04-2006, 05:25 PM
