586,651 active members*
2,744 visitors online*
Results 1 to 8 of 8
    Apr 2006
    439
    Question Mach3 tool table save / print ?
    Has anyone found a way to easily save or print the tool table in a readable format ?
    I save the Tools.dat file when updating mach But it would be nice to have a printout of my tooltable in the office with my Cam program.
    Scott
    www.sdmfabricating.com
    tool table
    Quote Originally Posted by Scott_M View Post
    Scott
    I have printed mine out in Excel but it takes a little editing to get it printed in a reasonable form/sheet.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
    Jul 2007
    438
    i am no computer guru so there may be an easier, less crude way to do it. if i just wanted a readable tool table i could print out, i'd probably just take a screen shot of it and save it as a jpeg.
    332
    print tool information
    I've made a vb script that runs when the save tool information button is pressed on the offsets page. It prints a text file to the desktop. I added it using the mach3 screen designer available at http://www.artsoftcontrols.com/downloads.php
    I don't have the script in front of me but I'll copy it and post later.
    Apr 2006
    439
    Thanks Keith ! That would be great.
    Scott
    332
    I do not use the lockdown Tormach version of Mach3. I download the full Mach3 from artsoftcontrols.com and use the Tormach screen set.
    (Menu at the top of the program, something like "view" and select the screenset you want)
    '''''Make a copy of your Tormach screen set (rename) to keep an original''''''''
    download the original Mach3 Screen editor from artsoftcontrols.com/download (there are newer editors but I don't know anything about them)
    Open the screen editor
    Open the (file).set that you use for Tormach
    Find the offset screen
    double click the "Edit/Save Table Now" button
    paste the text between the asterisks
    click the radio button "Execute VB Script"
    save the change and save the set
    load tormach or mach3 and try it out
    If GetDRO (24) = 0 Then
    DoOEMButton 121
    Else
    Message "You can only Edit/Save Tooltable when Tool #0 is selected"
    End If
    ' create or overwrite file = C:\Documents and Settings\All Users\Desktop\ToolInfo.txt
    ' vb script written by Edward Skeels (keithorr)
    textFilePath = "C:\Documents and Settings\All Users\Desktop\ToolInfo.txt"
    Set objFSO = CreateObject("Scripting.FileSystemObject")
    Set objTextFile = objFSO.CreateTextFile(textFilePath)
    Do Until num=225 'will write up to 225 tools
    num=num+1
    N = GetToolDesc(num)
    D = GetToolParam(num,1)
    L = GetToolParam(num,2)
    If N <>"Empty" Then
    objTextFile.WriteLine("Tool"& num &" "& N &" Diameter: "& D &" Length: "& L & Chr(13) & Chr(10))
    Else
    End If
    Loop
    objTextFile.Close
    Apr 2006
    439
    Thanks !
    I am familiar with the screen editor......and not afraid to use it !
    I will mess with this tonight and let you know.
    Scott
    Apr 2006
    439
    Many many thanks ! That is exactly what I was looking for.
    Easy to do , simple results. it took about 5 minutes to do.
    If you do not mind I would like to post your code in the other forum thread I have in the Mach forum.
    Again
    Many thanks ! That is just what I needed.
    Scott
  1. Replies: 3
    Last Post: 01-05-2009, 02:36 PM
  2. Can someone Please help me how to save my mach3 configuration as a xml file
    By JaiTalkin in forum Machines running Mach Software
    Last Post: 06-04-2008, 05:29 AM
  3. Mach3, G100 and an XY table.
    By Golden1ce in forum Machines running Mach Software
    Last Post: 05-27-2008, 03:34 PM
  4. Anyone running Mach3 with a DynaCNC table top?
    By CrashMasterKev in forum Machines running Mach Software
    Last Post: 11-22-2006, 03:36 AM
