586,094 active members*
3,942 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Life Without Flood Coolant
Results 1 to 13 of 13
    May 2005
    2502
    I just put out an article on dry machining on CNC Cookbook for those who are interested:
    http://www.cnccookbook.com/CCDryMachining.html
    I know a lot of folks here do not have flood coolant. It's surprising just how well you can do without it, but you do have to offset the loss of flood with some techniques to cover your bases.
    It's too long to put in a forum, else I'd just have copied it over.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Nov 2009
    4415
    Bob, I just read most of the article. Thanks. On the other hand I think I had read you went to Rice here in Houston. How much time did you spend at Valhalla's?
    May 2005
    2502
    Valhalla, LOL.
    More time at Willy's and the surrounding West U establishments. What a great scene. Marfreless, La Columb d'Or, etc. No end of places to enjoy a nice drink.
    Cheers,
    BW
    Aug 2007
    62
    I do all my hardmilling, and any milling for that matter, with Acculube air oil mist, the only thing I ever use coolant for is washing the chips out of the machine.
    Nov 2009
    4415
    Yep know all of those places. Was raised in and around West U, back when it was blue collar and the Village was dead (parents bought a corner lot & house in Southside Place for $24,000.00). Used to drink underage in Valhalla's, Shiners for .25! Never attended classes there. Couldnt understand what the girls were talking about and they werent supermodels (mid 70's). Anyway still live in the Heights. Love your work. Btw when are you going to free those inner boxes of your Turner's Cube? That avatar should be representative of your work. Maybe like Marcel's? Maybe he could lend you one to take a picture of
    Quote Originally Posted by BobWarfield View Post
    Valhalla, LOL.
    Cheers,
    BW
    Nov 2009
    4415
    Mom still owns that house. Doesnt want to sell it due to the capital gains! What a problem to have huh? The buyer would bulldoze it the next day. Only 2400sf :violin:
    May 2005
    2502
    Quote Originally Posted by Fastest1 View Post
    Not hard to free the inner boxes. My problem is my pathetic little rectilinear engineer's mind actually prefers the order and symmetry of leaving them where they are.
    Cheers,
    BW
    Aug 2007
    339
    The problem with machining without coolent is heat. You will be hard pressed to produce good parts while they are hot or warm, because when they cool you will be too small and have made junk.
    Like the saying goes, " Sure looks nice. How do they check?"
    We all live in Tents! Some live in content others live in discontent.
    Mar 2006
    2712
    If your parts get hot, you're going too slow LOL
    We dry hobbed gears @ 850 sfpm and were cool to the touch. Chips were basically dust, looked like dry grinding grit. Lotsa sparks!!!! Vacuum cleaner for chip removal.
    Dick Z
    DZASTR
    May 2005
    2502
    Boots, Dick Z has it. You want to get your feeds and speeds right so most of the heat goes out in the chips. High speed machining strategies ensure the part and tool get "cooling time" by managing cutter engagement and relying on chip thinning to allow high enough feedrates to keep the MRR's up.
    A little mist will also help by lubricating the part so less heat is generated in the first place.
    But in the end, if you want to complete eliminate the heat difference between coolant and dry machining, see the article's thoughts on using a Vortex Tube.
    Cheers,
    BW
    Jul 2010
    No flood coolant
    I agree completely. With the right speeds feeds and cutters almost all heat can be kept out of the part. Proof of this is on youtube under "high speed machining(really high). .625 endmill 10000 rpm 800 ipm and a part that is cool to the touch after almost 3 minutes of this. also no mist sprayer or air gun.
    Oct 2005
    1237
    I thought I saw an Excell spread sheet program that gave diameters and cut depth for toothed belt pulleys on your sight. At the time it had an under $15 cost but I was too cheap to uy it (then). Was that you, and if so, do you still offer it? I looked through your site and didn't see it.
    Mar 2006
    2712
    If you use coolant or lubricants in high speed machining, be sure it's compatible with the coating on the cutting tool.
    Most coolants and oils will cause rapid leaching of components in the coatings when subjected to the heat being carried off with the chips. Learned that the hard way.
    Dick Z
    DZASTR
  1. Flood coolant option
    By truline in forum Haas Mills
    Last Post: 05-19-2011, 12:00 AM
  2. flood coolant
    By FUBAR62172 in forum Community Club House
    Last Post: 06-05-2010, 09:32 PM
  3. flood coolant and way oil
    By dlaery in forum Taig Mills / Lathes
    Last Post: 06-04-2010, 05:58 PM
  4. NM-135 and Flood coolant
    By David Da Costa in forum Novakon
    Last Post: 02-11-2010, 04:18 PM
  5. My SX3 flood coolant base
    By metalworkz in forum Syil Products
    Last Post: 09-16-2007, 10:24 PM
