586,077 active members*
3,793 visitors online*
    May 2010
    Motors not moving
    Is any of you own RMS Technologies R701 and if you do can you send me a sketch of how you connected it to the breakout board I can’t get my motors to work with my configuration although it seems that they get energized but no movement
    Attached Files Attached Files
    Mar 2008
    3655
    If the motors lock up, then they are probably wired correctly to the BOB. This sounds like the board is either defective, or not receiving step/direction signals. Check your parallel port. (Can you print to a printer with it?) Make sure that your parallel cable is a "straight thru" type. Try a different computer.
    This is from the docs:
    The Motor is in Holding Position, but does not rotate:
    This means that Power is being supplied to the driver and motor, so the power supply is OK. However, the signal generator might be causing the problem. Try changing the signal to TTL. If this doesn't help, is the external +5 VDC Power connected?
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    May 2010
    what should I do
    "Try changing the signal to TTL."
    how would I do that...I thought that it is by choosing ECP or EPP I am really stump now.
    May 2010
    Quote Originally Posted by neric View Post
    ECP/EPP is not a problem for Windows/Mach3. But you must set it to EPP for Linux/EMC2.
    It looks like your driver is not getting step signal. Check the pin config at Mach whether they are correct.
  1. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 07:48 PM
  2. Mach3 not moving motors
    By jasper371 in forum Mach Mill
    Last Post: 06-15-2009, 10:32 PM
  3. Motors not moving
    By lamicron in forum Mach Mill
    Last Post: 05-20-2008, 01:54 AM
  4. Discussion of moving table vs moving gantry
    By rkremser in forum DIY CNC Router Table Machines
    Last Post: 02-20-2008, 10:59 PM
  5. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
