586,268 active members*
3,426 visitors online*
    Sep 2009
    29
    What do you do with your water table waste water?
    So I am going back and forth between a water table vs. a drawdown type exhaust fan. The table I am building is for a commercial use and will have to be designed around some regulatory factors. One such factor to be taken into consideration is the proper disposal of the waste water from a water table type system. What are you guys doing when it comes to disposing of your water when performing regular cleaning? How fast does the water get dirty and need cleaning, (hours of cut time). If I have to have a hazardous materials group come in an pick up and dispose of the water on a monthly basis the operating cost will be too much.
    Any advise or comments are welcome as I am trying to put together a pros and cons list for the two types of systems.
    Brian
    Mar 2004
    54
    in the water table of the Fastcut G6 fabricator we have at work we use greencut and it it non toxic and safe for municipal sewer dumping ( as well as septic safe ) the test report they sent with it says that fish can live in it under 20% concentration but we did'nt put any goldfish in the water table to see if that was true or not
    as far as the lifespan of the solution all we do is top up the water occasionally, so far so good ....zero rust
  1. Does anybody know what to mix in the water, on a water table?
    By suzukirmz in forum Waterjet General Topics
    Last Post: 06-22-2008, 05:56 AM
  2. Water Table
    By Big John T in forum Waterjet General Topics
    Last Post: 06-06-2008, 09:11 PM
  3. Water Table
    Last Post: 05-07-2008, 02:32 PM
  4. Water Table FS
    By bgmnn in forum Welding Brazing Soldering Sealing
    Last Post: 04-27-2008, 11:01 PM
  5. Water transfer techniques for water table?
    By Knut in forum Waterjet General Topics
    Last Post: 02-02-2007, 04:52 PM
