586,113 active members*
3,172 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Horizontal / vertical mill How to post ?
Results 1 to 3 of 3
    Feb 2008
    25
    I have a Deckel FP4nc mill, this machine can work as a vertical or as a horizontal mill. the problem I am having is that if I want to use the horizontal spindle, my depths will be determined by the Y axis. If I use a vertical machine post processor, it outputs the depths as Z movements.
    Other than swapping Y's and Z's on the editor (using replace all) how can I do it in Mastercam? Mastercam X
    Jun 2008
    372
    There are 2 solutions
    1 - Custom Post
    2 - Edit the code, You will also need to change any arcs
    Mar 2006
    1013
    Used to be an applications Engineer for Hermle. Same kind of machines, Universal Mill. I had a Heidenhain post that would output vertical toolpaths for horizontal (Y=Z) toolpaths.
    i.e. Custom Post
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
  1. kempsmith #4 mill (horizontal/vertical )
    By Goldhunter_2 in forum Uncategorised MetalWorking Machines
    Last Post: 11-19-2009, 10:08 PM
  2. Looking for a 7x12 Horizontal / Vertical Bandsaw... Recommendations?
    By PhoenixMetal in forum Uncategorised MetalWorking Machines
    Last Post: 06-11-2009, 01:30 PM
  3. Machinist - Horizontal / Vertical boring mill operators
    By quinnj in forum Employment Opportunity
    Last Post: 10-18-2007, 05:26 PM
  4. Horizontal and Vertical boring mill operators
    Last Post: 10-16-2007, 07:58 PM
  5. Vertical/Horizontal Bandsaw purchase
    By ChrisJ in forum MetalWork Discussion
    Last Post: 07-21-2007, 02:30 PM
