Hello, I bought a tb6560 5 axis driver board. I use mach 3 sw for driving the step motors, but I have a problem : when I start mach 3 the holding torque about step motors go down and the step motors don't run, infact the 5 led about the axis segnals aren't bright. I set the pins following the driver boards instruction. When I go to see the active pins on mach 3 there are no output pin switch on. I think that the setting pins write in the instruction aren't ok. what do you know?
The pins are:
X ENALBED14 STEP 16 DIR4
Y ENABLED14 STEP 1 DIR17
Z ENBALED14 STEP 7 DIR3
THANKS VERY MUCH
SORRY IF MY ENGLISH IS POOR
