Not a good thing
Those rails and blocks should not be going bad on you this quickly. Something to check may be to see if the rails are aligned good. If not, it could be causing premature wear. Are the wipers on the blocks in good shape, any bellows installed? Anything that may prevent debris from entering the area? Waterjet media is course and abrasive by nature and can destroy linear motion components if they are not protected.
25 series should be plenty strong enough for all but the largest machines.
Hope this helps.
Check out what I am working on at www.routerbitz.com!
