586,094 active members*
4,112 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > Need Help hooking up Viper200 Stop-Out lines to CNC4PC C1 BOB Input Lines
    Mar 2007
    304
    I am in the final stages of finishing up my 1985 SuperMax Anilam Crusader 2 conversion to Larken Viper200's. I have the mill up and running, the servo's reasonably tuned. I am very impressed with what I can now do with this machine (Mach3, Vectric VCarve Pro, etc.).
    However, I am having troubles getting the Fault lines to work with my CNC4PC C1 Break Out Board (BOB).
    I have wired the 12 Volt Ground for the Viper200's, and the 5 Volt Ground of the CNC4PC BOB to one common ground (backplane of the electrical panel).
    I have wired the Viper200 "Stop Out" to the Input #11 on the CNC4PC BOB.
    I can not get the input to see a change of state - by forcing the Viper200 into fault mode by turning the trimpots on the Viper200. It does cause a fault on the Viper200 (evidenced by the RED LED's on and flashing).
    It does not change state on the input of the BOB though.
    Has anyone interfaced a CNC4PC BOB with the Viper200's and gotten the faults to work?
    If so - any help is greatly appreciated.
    Thanks!
    Joe
    (CNC isn't a passion..... its an addiction...)
    www.CNC-Joe.com
    CNC Is Not Just My Passion.. It's My Addiction !!!!
    Mar 2007
    304
    Just thought I'd update this post.
    I did get this worked out. I had a couple of problems.
    1) I did not have the CNC4PC C1 BOB properly set to the "PULL-UP" position on the resistor jumper. I blame this on a dark electrical cabinet and my bad eyesight. A couple of nice bright magnetic LED lights, and moving the right jumper helped.
    2) The next problem I had was that I didn't have a good enough ground between the CNC4PC C1 BOB 5 volt power supply ground and the 12 volt Viper200 ground and the back plane of the cabinet. I basically have everything on the same ground - so that it doesn't float.. I re-tapped the hole, and made sure it had a good ground - and that also helped.
    3) Next I went to Mach3, Config-> Ports and Pins-> Inputs-> and set up the input, went to the viper board and turned the current limit pot until it triggered a latched fault..and whah-lah - the fault mode is now working.
    Nice to see this old mill able to run for hours now, running megabytes of machine code.
    I will put out a booklet on my conversion in the near future. But its pretty much done (wait a minute.... are these projects ever really done??? heck no - there's always things that you want to add.. )
    I did add an electronic Z-zero plate to the set-up - and that works great.
    I will also be adding an electronic edge finder in the future too
    www.CNC-Joe.com
  1. PVC Compressed Air lines
    By Five-10 in forum Community Club House
    Last Post: 01-07-2011, 02:51 PM
  2. Blowing air lines
    By Delw in forum Haas Mills
    Last Post: 10-04-2009, 09:30 AM
  3. parallel lines
    By daisydog in forum Rhino 3D
    Last Post: 02-09-2008, 05:34 AM
  4. Lines in mold
    By DH2000 in forum Moldmaking
    Last Post: 01-07-2008, 03:50 AM
  5. Can't see lines
    By Mr.Chips in forum Uncategorised CAM Discussion
    Last Post: 04-03-2005, 04:29 PM
