586,062 active members*
4,656 visitors online*
    Aug 2010
    looking for a cheap machine
    So guys, been a lurker for a bit here, but decided to post. I'm still a newbie though, so bear with me if I make some mistakes.
    I'm looking for a cheap machine, preferably turnkey, to:
    1. Mill Expanded PVC (Sintra, Komatex, Komacel...). It's foam but behaves like plastic. Apparently easy to cut.
    I'll be almost milling a bowl out from a block, if that makes sense as to what I'm doing.
    2. Mill PCB's. I'm looking to do some fine trace PCB's, so I'll be needing little backlash and tolerances.
    Not as important, but preferable...
    3. Wooden Signs
    4. Mill Copper sheets (and drill holes)
    I also need the travels to be at least 1' x 2' x 3".
    I found the Fireball V90, seems to fit my needs well. But I heard the motors get quite hot, so I was thinking about replacing the driver boards with the linistepper boards.
    Any suggestions?
    Mar 2008
    3655
    Sure. Go with the bare kit and supply your own electronics:
    http://crevicereamer.com/Page__57.html
    CR.
    Too many PMs. Email me to my name plus At A O L dot com.
  1. cheap cnc machine
    By s3rius385 in forum Open Source CNC Machine Designs
    Last Post: 12-28-2010, 04:11 AM
  2. Cheap CNC milling machine
    By monstrum in forum Uncategorised MetalWorking Machines
    Last Post: 08-04-2010, 04:08 PM
  3. Cheap machine guard?
    By JamesJames in forum Safety Zone
    Last Post: 12-18-2007, 10:45 PM
  4. Cheap Circuit Board CNC Machine?
    By Ian Cunningham in forum European Club House
    Last Post: 03-02-2005, 04:31 PM
  5. new cheap mdf machine
    By Hobbiest in forum DIY CNC Router Table Machines
    Last Post: 02-25-2004, 05:54 AM
