586,219 active members*
3,372 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow 500 1996 trouble a2100
Results 1 to 10 of 10
    Apr 2010
    7
    I recently aquired this machine at auction. Thanks to all the support at this site I have replaced the hard drive with one off ebay. It is now showing a 4000f system fail, which is the dv5 board I quess. Here is my question, when I power up the machine the contactor that powers the dc bus is never engaged, the drives are showing undervolts - duh. All 3 axis appear to be at their limits. Do I need to manually move them off the switches before I can get them to power up? I cannot find any info in the schematic or manuals. I don't really want to screw this thing up if I can avoid it.
    Any help is appreciated.
    eric
    May 2006
    82
    Hi ReBco.
    The contactor that you refer , it actually feeds with 3 phase volt. to DC power supply wich gives the DC 350 VDC
    As long as you have a software related problem or e-stop condition you will not be able to see the *machine power required prompt*
    In normal conditions , after this message appears , the power button
    is pressed and the contactor should be energized & maintened,
    Apr 2010
    7
    OK, I see this on the wiring diagram. Thanks for the insight. CR5 is not closing- at what point is this relay closed? As soon as the cpu is turned on the fault light on the dv5 board lights up. Is this a bad omen? Just looking for a place to start. Also the i/o board has no fault or enable lights lit up.
    thanks
    for all help.
    eric
    I think I will reseat the boards and see if that works.
    Aug 2010
    arrow 500
    Hi Eric
    I just bought an Cincinnati Milacron Arrow 500 1995 from an auction in Germany. After installation and setup looks like SWARF REMOVAL TRAYS are missing.
    **Please help me and make a picture with yours so I can replicate them.**
    I have lot of documentation in English and German (programming manual just German, I'm looking for english) and if you need I can help.
    [email protected].
    David
    Feb 2009
    6028
    No power to the drives, etc would be totally normal with a CPU error. You said you got a hard drive off ebay, is it for the EXACT machine model? All the configuration data is on that drive, different i/o's or axis drives etc will cause big issues.
    Aug 2008
    386
    Quote Originally Posted by dadam View Post
    Hi Eric
    [email protected].
    David
    Did you get the coolant tanks?
    The trays would be pretty hard to replicate, it would likely require more than just pictures.
    I can get some pictures for you in the next day or so if you'd like.
    Joe
    Aug 2010
    swarf trays
    Hi Joe,
    Yes I got the tanks. Replicate it might be a big word for what I will do, but I need to do something. Please make some pictures with yours so I can figure out how to do it. I'll attach pictures to see what I get here.
    correct email is [email protected]
    David
    Aug 2008
    386
    I'll try to get some pictures tomorrow.
    Joe
    Aug 2008
    386
    I tried emailing you the pics today and it bounced.
    Want to provide a valid email address?
    Joe
    Aug 2010
    Hi Joe,
    Sorry for that. Try this: [email protected] as a company email , but old one should works, too. [email protected][david([email protected]]
    David
  1. Tool Changer Messed up Arrow 500 A2100
    By Pau2752 in forum Cincinnati CNC
    Last Post: 04-27-2011, 07:37 PM
  2. A2100 - Arrow 1000: Operating System Lost
    By JTG2003 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-09-2010, 04:33 AM
  3. Arrow 1000 spindle trouble
    By raygun in forum Cincinnati CNC
    Last Post: 03-03-2009, 04:32 AM
  4. A2100 and tool probe Arrow
    By brokenrinker in forum Cincinnati CNC
    Last Post: 01-23-2009, 10:37 PM
  5. trouble to align cincinnati arrow 1000 (1998)
    By aherrc in forum Servo Motors / Drives
    Last Post: 03-08-2008, 12:16 AM
