586,051 active members*
3,945 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > 1720 XMTC Manual and Compound Slide
    Aug 2010
    Hi there. I just bought a used 1720 XMTC Gold, and am looking to get my hands on an owners manual. Does anyone have, or know where I can get a pdf copy?
    Also, if its not a really dumb question, the machine I bought came with a tool post that fixes directly to the cross slide, without a compound slide. I can see that the entire cross slide / milling table can be rotated, but without a compound slide, I can't see how I would machine a taper using the lathe. For example, if I wanted to make a dead centre out of a round bar, how would I do so without a compound slide? I hope I'm missing something obvious, and not missing some important part of the machine!! Any guidance is greatly appreciated!
    Cheers ...... Simon
    Jan 2008
    458
    Quote Originally Posted by grahasp View Post
    Cheers ...... Simon
    On the older 17-20 models the only way to cut tapers was to rotate the entire table to the desired angle. When I got my first machine I found it to be a bit clumsy, especially on small parts. You set the Y axis table to the angle you want and use it to cut the taper- use the X axis to set the depths of your cuts. It was a compromise design to allow angle milling, which was a big bonus. The later compounds they sell will fit your machine. A couple of things to watch out for- Do not rely on those rivet on degree scales- especially on a used machine- they can get bent out of position. Use a dial indicator across the face of your chuck to find the 90 degreee position and then make a permanent mark on the 2 rotating surfaces. Then use an angle finder to set all your various tapers.
    Aug 2010
    Thanks Smallblock. Appreciate the advice.
  1. Doing away with the compound slide
    By rkovvur in forum Mini Lathe
    Last Post: 06-21-2010, 09:48 PM
  2. 1720 XMTC White - quill tool holder?
    By Knn in forum Shopmaster/Shoptask
    Last Post: 10-16-2009, 05:36 PM
  3. Replies: 9
    Last Post: 08-14-2009, 03:07 PM
  4. cross slide and compound rest
    By krymis in forum Mini Lathe
    Last Post: 02-10-2008, 04:42 AM
  5. Enco Compound Slide Milling & Compound Drilling Table
    By 7ofclubs in forum DIY CNC Router Table Machines
    Last Post: 12-24-2006, 05:43 AM
