586,060 active members*
3,736 visitors online*
Thread: XZero CNC
Page 225 of 226 125175215223224225226
Results 4,481 to 4,500 of 4515
  1. #4481
    Jun 2007
    3891
    Re: XZero CNC
    sold separate as an option. you could make your own pretty easy from some angle aluminium.
  2. #4482
    Jan 2007
    235
    Quote Originally Posted by ihavenofish View Post
    Thanks.
  3. #4483
    Oct 2013
    30
    Re: XZero CNC
    What have others used as a bracket for mounting the cable chain for the X and Y axis on their XZero machines? I have a 30 x 60 Raptor that I'm finally trying to button up. I'll likely just make a crude bracket out of a piece of aluminum flat bar for the time being and revisit it later.
  4. #4484
    Oct 2013
    30
    Re: XZero CNC
    Before I break out the calipers, can anyone tell me if the end machining on the Raptor ballscrews is the same as what is typically available from the eBay vendors? Or are the ballscrews on the Raptors machined to George's specifications. I want to replace the 1605 Y axis ballscrew with a 1610 as that is what I was supposed to have received with my machine. I was hoping that I can just specify the overall length to match the screw that I have and be good to go. Was the Raptor ever available with a 20mm dia. Y axis ballscrew? My 30x60 machine has a 20mm dia. ballscrew on the X axis so having a matching 20mm dia. on the Y axis would be nice if a larger ballnut mount could be made to fit behind the existing Z carriage, although I suspect there's very little benefit to going to a larger dia. ballscrew.
  5. #4485
    Jun 2007
    3891
    Re: XZero CNC
    end machining on xzero machines are special for the xzero bearing blocks and its changed a few times over the years. if its a newer one, with a threaded nut, it should be easy to measure and send out to have it replicated. the older ones sometimes has press fit tolerances on the bearings or threaded couplings.
    the raptor was always 16mm screws on y and z. not any room for anything else (unless you went to very expensive compact screws)
    it should be noted that georges screws are not the same as the cheap ones littered all over ebay, and end machining concentricity is (apparently) not trivial for just any old person with a lathe in china to do. actually it was pretty hard for the guys over here to do as well. all the newer ones were done by the factory (TBI models i think on all machines now).
  6. #4486
    Oct 2013
    30
    Re: XZero CNC
    I would rather get the correct ballscrew from George if that's an option, I'm currently waiting on a reply from him.
  7. #4487
    Jun 2007
    3891
    Re: XZero CNC
    yeah, thats the best if hes able to get you one in a timely manner
  8. #4488
    Oct 2015
    15
    Re: XZero CNC
    Anyone hear from George recently? I'm still waiting for some parts to finish my build and it's been a very long time now with a lot of "next week" promises. I didn't want to take this to the public forum, but he's seen my facebook messages and have not replied to any of them.
    Feeling like I'm running out of options here. The Predator has been sitting partially assembled for the past 6 months and I've been more than patient with missing parts after throwing down the funds for this project and buying the best equipment there is.
    Besides the missing assembly manual, I've been waiting on the correct motor mounts, sensor plates and questions to other parts now. Not sure how much longer I can afford to wait.
    Does anyone else here have the new predator and was successful at completing it?
  9. #4489
    Jun 2007
    3891
    Re: XZero CNC
    Quote Originally Posted by crash416 View Post
    George had a stroke in January, his recovery is coming along, but its sporadic to get in touch with him.
    his website got hacked in the meantime, so that and his old email are toast.
    I do not know about the facebook account - weather its him running it, or a helper. I would not assume hes seen any of it himself.
    I don't know if hes still helping out on this front, but ryanscustom on this forum may be able to sort you out for missing parts, or at least direct you to the right contact - hes the guy that actually makes the frame parts.
    on the assembly manual ive never has the need for one. is there one? people here should be able to sort you out on that front, just ask about which area you are having trouble
  10. #4490
    Jun 2007
    3891
    Re: XZero CNC
    I see your other thread... I see a few things assembled wong in the pic - ball screw nut mounted on the wrong side of the housing for the x (long axis) being one.
    I see motor mounts that look fine. the couplings are correct - yes they are short, but that's they way they are meant to be. if those are leadshine easy servos, then yeah, they have shafts that are much too long. longer than other nema 34 motors. I have the same. I needed about 8mm in spacers (washers) to stand them off the motor mounts. ideally there should be an extended motor mount, or a shim, but washers work fine. one of your couplings looks odd. is that the z? it sticks out waaaaaaaaaaaaaaaaay too far. I thnk its because that end plate is not 1" like the rest of them. youd need an extra 12mm of "shim". that's a bit of a confusing error on the machine. I wonder why that happened. maybe you have mixed some parts up in the wrong axis. I have to look closer.
    hmm.
    (edit - nope, somethings quite with with the z.)
  11. #4491
    Oct 2015
    15
    Re: XZero CNC
    hmm.
    Can't believe I haven't seen your reply until now!!!
    I had a chat with George recently and he pointed out the same as well. But since I haven't touched the kit in a long time, I couldn't quite remember what parts went where.
    Assembly was done based on what was available at the time, reference material for Raptor and whatever CAD rendering George had on Facebook. Never assembled one of these before and without directions or instructions due to circumstances and new nature of the machine, it was all guess work.
    Can you elaborate on the ball screw nut? Most of the parts I have are numbered, but there really aren't any logical sequencing to them, so not exactly sure what is on backwards (Long axis)
    Regarding the end plates for the machines, I believe they are all the same if I remember correctly. My Y axis ball screw bearing isn't seated entirely in the housing since I assumed the screw was a tad short. Will try to get some photos this weekend!
  12. #4492
    Jun 2007
    3891
    Re: XZero CNC
    the round part of the ball nut should go through the housing. in alot of ways it doesnt matter, but it can help aligning during assembly
  13. #4493
    Jun 2007
    3891
    Re: XZero CNC
    so I have a few xzero parts and related things I need to get rid of.
    I have many parts of a predator frame.
    - uprights
    - end frames
    - gantry back plate
    - gantry backing bars
    - Z axis complete with 2510 ball screw and sbc rails and motor mount
    - dual X 2525 ball screws
    - y 2525 ball screw
    - dual x ball screw supports with double row bearings
    - y axis ball screw supports with double row bearing
    - 3 nema34 motor mounts
    - SBC 25mm x rails 48"
    - SBC 25mm rails 24" (too short of y)
    - 6 pieces SBC 25mm long blocks used on y and z
    a few other bits:
    - 4 nema34 8nm leadshine easy servo 110v motors and drives.
    - a nice shiny teknomotor iso30 spindle with drive and air system and 5 er32 tool holders with 5 extra pull studs.
    all of these things are "new" although they have been hanging around for a few years and dusty and possibly scuffed in spots.
    message me if youd like any of this!
  14. #4494
    Feb 2007
    966
    Re: XZero CNC
    Thats too bad to hear about George.
    Hows he doing ?.. How old is he btw ?
  15. #4495
    Jun 2007
    3891
    Re: XZero CNC
    im not really sure how hes doing. he calls once in a while, then vanishes again. hes not that old, 50's I think.
  16. #4496
    Jan 2012
    30
    Re: XZero CNC
    @ ihavenofish
    Sent you a PM several days ago about the parts your selling. If they are still available, please get back to me.
    Thanks, Brian P.
  17. #4497
    Jun 2007
    3891
    Re: XZero CNC
    replied
  18. #4498
    Sep 2011
    9
    Re: XZero CNC
    Hello everybody.
    I ordered a Predator 25x60 (new model 2017) just when George had the stroke. I paid and receive few pieces, but after stroke It is almost impossible to have a response from George...
    Anyways, I need to finish this machine I ordered 2 years ago, and I need few pieces, I hope you guys can help me:
    -Blocks and rails (I need Brand and model for all Axis)
    -Screws for all axis (where to buy it)
    .Aluminum table top (where to buy it)
    Thank you in advance!!!
  19. #4499
    15362
    Re: XZero CNC
    Quote Originally Posted by pratbasses View Post
    Hello everybody.
    I think he has been on Facebook, if you can find his contact, the rails where Hiwin HG series check the Bearing mounting on the aluminum machined parts, this will give you the type of bearing block he used
    The mounting of the rails should give you what size he used as well, they could be 20mm or 25mm just check the center distance from the mounting holes to the shoulder on the machined parts
    The aluminum table top was his own custom profile, he most likely still has this unless he sold everything, you could use anything you want for a table you may have to get creative with that part
    Mactec54
  20. #4500
    Jun 2007
    3891
    Re: XZero CNC
    25? are you SURE its a predator, and not a raptor? I don't remember there being a 25 predator. This is important as they take different sized rails.
    Assuming a predator:
    Blocks and rails were TBI 25mm narrow blocks. 4 standard blocks on the x and 2 each long blocks on the y and z. I would not get TBI, the commonly available ones have no preload and are prone to damage and not very well sealed. George used them cause they were decent for very cheap, but you wont get his pricing so there is no reason to go cheap. SBC are a better choice, but will run you $1000+ for the machine. There is a good Korean seller on ebay that may have some well priced surplus THK and NSK and Bosch etc, but make sure they are preloaded (youll have to read the model codes).
    Hiwin is also good for maybe under $1000 "retail", though not quite as nice as sbc or thk. Again, make sure they are preloaded.
    Screws are m6 shcs. 16mm length if I remember right. There are inserts for mounting the rails to the X extrusions. I don't know where George got his. The ones he used are MUCH nicer and heavier than any of the ones ive found online. (ive actually replaced my extrusions with solid bars).
    Table top is not available unless George gets well enough to get a run going - as of right now, that's not happening. If that does happen, it could be months or years from now, I cant guess. I used a 1" mic6 plate for my table, but this is of course rather expensive - $800+ just for the metal (I still don't know why aluminium made in Norway and sold in Canada has gone up due to trumpy boy's tarrifs...)
    Anyhow, good luck, and feel free to post the rails and blocks link before you buy to confirm if its the right one.
  1. XZero CNC
    By gio666 in forum News Announcements
    Last Post: 04-30-2013, 05:53 AM
