586,104 active members*
3,276 visitors online*
Thread: XZero CNC
Page 199 of 226 99149189197198199200201209
Results 3,961 to 3,980 of 4515
  1. #3961
    May 2008
    4068
    Re: XZero CNC
    Quote Originally Posted by blitz355 View Post
    Do these blocks use a z0 preload? Normal preload or Light?
    SBC have a K1 pre load, i guess same as Hiwin Z1 . Z0 pre- load is how most of the blocks are sold
    XZero cnc
  2. #3962
    Jan 2013
    52
    Re: XZero CNC
    Quote Originally Posted by gio666 View Post
    Are the tbi blocks you use z0?
    Thanks!
  3. #3963
    May 2008
    4068
    Re: XZero CNC
    Thanks!
    I guess they should be, Z0 is Hiwin number
    XZero cnc
  4. #3964
    Jan 2013
    52
    Re: XZero CNC
    Ok, thanks. I believe youre right. Z0 is normal with z1 being slight preload
  5. #3965
    May 2008
    4068
    Re: XZero CNC
    They all have a different way of rating,light pre load z2 on the tbi blocks. if wanting higher pre load you can change bearings inside block. it is very easy
    Also there is so many counterfeit TBI ballscrews and blocks out there, with them you never know what you get
    XZero cnc
  6. #3966
    Jan 2013
    52
    Re: XZero CNC
    Even if the place is noted as a supplier on tbi's website? Z0- no preload/normal
    Z1- light z2- medium z3-heavy
    Do you just change out the ball bearings? Where do you get these from?
  7. #3967
    Jun 2007
    3891
    Re: XZero CNC
    bearings you can buy in 0.0005" (or less) increments from some suppliers on ebay. its cheaper if you can buy them already set up correctly of course, but if you need to change existing blocks, it should be fine. 20mm blocks take 1/8" balls (yes, not metric). 0.1255 should get you medium preload.
  8. #3968
    Jan 2013
    52
    Re: XZero CNC
    Quote Originally Posted by ihavenofish View Post
    Is medium preload recommended? I think the sbc bearing he uses, like he said k1. K1 according to sbc data sheet is normal, and k2 is "light".
    Good to know that you can find them on ebay, do you search anything specifically or just "ball bearings"
  9. #3969
    Jun 2007
    3891
    Re: XZero CNC
    its a trade.
    less preload = less friction = less wear and higher speeds.
    more preload = more rigidity and more stiffness.
    in the case of a raptor, id think light to medium is good. no preload is actually adequate, although cutting aluminium i did notice some vibration at the blocks. even then i still have a good finish in relatively heavy cuts in aluminium
    what you DONT want is clearance (which is also an option from most manufacturers). this means the blocks are loose, usually for accomodating sloppy alignment in non precision equipment.
  10. #3970
    Oct 2014
    22
    Re: XZero CNC
    Anyone knows the torque needed for setting the various raptor screws? ex (end frame to extrusions, profile rails)
    Cyprus customs wins the world slowest port customs award. Arrived Feb 13th... still waiting.
  11. #3971
    Jan 2013
    52
    Re: XZero CNC
    its a trade.
    Yea that all seems to align with what ive read elsewhere, thanks for mentioning your experiences with aluminum. Good to know that the no preload/normal still gives a decent finish (obviously the rest of the machine needs to be up to snuff).
  12. #3972
    Sep 2014
    64
    Re: XZero CNC
    George, nice seeing you in Toronto today. Thanks for making the trip to get me the hardware I needed. It was nice of you to add in the drop-in nuts, over and above.
    All the best
    John
  13. #3973
    May 2008
    4068
    Re: XZero CNC
    What one company rates their blocks might not be same as other company.s, C5 ballscrew from china that they rate, nsk or THK rate it as c10 if not a lot higher.
    As a few people know , putting tbi blocks on rails its a little hard at first, So would not want any less clearance then that .
    - - - Updated - - -
    Quote Originally Posted by JohninOttawa View Post
    All the best
    John
    No problem
    XZero cnc
  14. #3974
    May 2008
    4068
    Re: XZero CNC
    Quote Originally Posted by infer66 View Post
    Yes it was a long time they had it. sometimes i get motors and drivers from states and they sit in Canada customs for 21 days. Which is even worst, they don't even open package to look inside?
    XZero cnc
  15. #3975
    May 2008
    4068
    Re: XZero CNC
    XZero cnc
  16. #3976
    Sep 2014
    64
    Re: XZero CNC
    Two quick questions this evening:
    1) Are you still offering Mach3 licences? If yes, what's the best way to buy one? I can't find a link on your website. A related question on the Mach 3 add on package - Any opinion on whether it's worthwhile?
    2) 4th axis - I know this was discussed a while back on the forum here. Is there a 4th axis offering from Xzero at present or planned?
    John
  17. #3977
    May 2008
    4068
    Re: XZero CNC
    John
    Hi John , yes i have the mach3, you just email me and ill give info .
    I will have the 4th axis is a couple weeks, i have finalized the design to use with mini Raptor or larger machine and just waiting for the part to get here
ID:	274176 Click image for larger version.
    XZero cnc
  18. #3978
    May 2008
    4068
    Re: XZero CNC
    Have new usb card to check out ill post info of it with leadshine steppers and leadshine servos
    XZero cnc
  19. #3979
    May 2008
    4068
    Re: XZero CNC
    Demon end frame with center 4080 if using dual ballscrews . having a total of 3 if using dual or single ballscrew it will be 2 4080 profiles
    Attachment 274182 Click image for larger version.
    XZero cnc
  20. #3980
    Jan 2007
    235
    Re: XZero CNC
    Cant wait!
  1. XZero CNC
    By gio666 in forum News Announcements
    Last Post: 04-30-2013, 05:53 AM
