586,082 active members*
3,905 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Newbie Question re: What machine and pieces per hour
Results 1 to 12 of 12
Threaded View
    Aug 2010
    Hi guys (and girls) am researching potential machine to run similar parts as the attached picture. Essentially it is several circles cut out of a 4x8 sheet of 3/4" plywood, along with 30 - 1/2 dia. holes.
    Not familiar with CNC routers and not sure what type of machine would be required in a production setting (m/c running 8 hours per day) and approximately how many 4x8 sheets could be processed in a days shift.
    As always cost is a factor which is why the Shopbot PRsalpha models look promising versus an expensive Multicam type brute.
    Hopefully someone can make some machine recomenedations along with approximate parts per hour.
    Thanks for all the help.
  1. Machine hour rate
    By Ganesh in forum Uncategorised MetalWorking Machines
    Last Post: 05-11-2010, 09:20 PM
  2. MACHINE SHOP 1 HOUR NORTH OF TORONTO LOOKING FOR CUSTOMERS
    By DublJ in forum Employment Opportunity
    Last Post: 04-25-2008, 04:46 AM
  3. Caculating pieces per hour SL20 Lathe
    By Rj10366 in forum Haas Lathes
    Last Post: 12-02-2007, 02:33 AM
  4. Newbie question: how do I machine this? (Drawing attached)
    By Aegeon in forum MetalWork Discussion
    Last Post: 12-04-2005, 08:20 PM
