586,103 active members*
3,703 visitors online*
    Oct 2008
    2100
    Radius to end of Arc Differs From Radius to Startline
    Ok... Why? I mean I used this G-code file to cut an actual work piece under my previous profile. However under the Gecko XML I get this error.
    What setting would be different that the code would be good in one, but not the other?
    I reloaded my old profile and loaded the same g-code file just to make sure and it did not stop at this as an error.
    Bob La Londe
    http://www.YumaBassMan.com
    Oct 2008
    2100
    Sorry if I posted that in the wrong area, but since it was related to a Gecko Drive change and XML file... oh nevermind. Just glad its where you want it now.
    Bob La Londe
    It's a Mach3 issue, not a Gecko issue, so I moved it to the Mach3 forum.
    As you saw in the Mach forum, it's probably due to the IJ mode. Change it in General Config.
  1. Replies: 8
    Last Post: 11-15-2009, 01:35 PM
  2. Radius to end of arc differs from radius to start?
    By Jamy in forum LinuxCNC (formerly EMC2)
    Last Post: 08-23-2009, 05:28 AM
  3. radius help
    By Scott Halstead in forum GibbsCAM
    Last Post: 06-12-2008, 01:27 PM
  4. "Radius to end of arc differs" problems !
    By Geetar-ist in forum G-Code Programing
    Last Post: 12-16-2007, 07:22 PM
  5. Zero Radius Arc
    By Xular in forum Mach Mill
    Last Post: 12-14-2006, 04:10 AM
