I recently was tasked with programming a Puma MX2000ST with the Fanuc 18i-TB control and I have a couple questions about the tool offsets.
When a tool is called, you must call M06 T28028 for tool 28 and offset 28. G43 simply comes back with "improper G-code". As far as that is concerned, how do you take care of the tool offsets when you are using the rotating head in various orientations? The X and Z offset values would clearly changed based upon the rotation. Do you neglect to use an offset in the machine and just take care of it in your post processor?
The Fanuc 18i manual discusses options such as high speed cutting / smoothing / tool center point compensation. Is there a way to determine what options are enabled on the machine just to see what my programming options are?
