586,094 active members*
4,137 visitors online*
    Feb 2005
    13
    Mach2 driver enable connection
    I want to configure my controller to run Mach2 but I need a port pin
    for "enable" on each axis. How do I connect these to MAch2 as their
    pin configutration does not allow for this?
    Hi:
    Mach2 has 6 enables, one for each axis. YOu simple turn on the enable 1 - Enable x and they will go active to enable each axis which is turned on in the config..
    (Mach3 also has a current reduction pin you could use if required...)
    www.gearotic.com
    Art Fenerty
  1. 4 Channel Stepper Driver Which One!
    By dewayne in forum CNC Machine Related Electronics
    Last Post: 07-09-2004, 03:47 AM
  2. Mach2 Faro Arm Inverse Kinematics
    By vacpress in forum Uncategorised CAM Discussion
    Last Post: 05-28-2004, 03:14 PM
  3. G Code and Mach2
    By InventIt in forum DIY CNC Router Table Machines
    Last Post: 03-13-2004, 08:46 PM
  4. Fun with floppy stepper and driver
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 08:18 AM
