586,035 active members*
3,620 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Advice Needed: Searching for a Small Motherboard
    Mar 2007
    304
    I am finishing the upgrade up to my 1985 CNC'd SuperMax YCM-30 Milling Machine, with Larken Viper200 controllers, CNC4PC C1 BOB, US Digital Rotary encoders, etc.
    I am running Mach3 off of an older desktop IBM NetVista computer - running Windows XP Pro. It is working great.
    I am considering purchasing a very small footprint motherboard and power supply - and putting that inside the electrical cabinet too - and thinking of purchasing it off of Ebay
    Can anyone give some advice on which motherboard to use for this?
    Thanks for your input,
    Joe
    www.CNC-Joe.com
    CNC Is Not Just My Passion.. It's My Addiction !!!!
    Feb 2007
    4553
    Post DG41MJ Core II motherboard
    Joe,
    Take a look at the Mini-ITX motherboards Intel makes.
    The DG41MJ Core II motherboard is a awesome deal and it even has a parallel port on board.
    http://www.intel.com/products/deskto...j-overview.htm
    We use lots of these boards and they work flawlessly.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Mar 2008
    267
    Joe,
    I use a mini atx motherboard from JETWAY model 72WE2G-OC-LF listed on linuxcnc wiki as a low latency motherboard.
    I chose this motherboard not for its size but rather for its latency performance ( important in realtime EMC2 setup).
    Mar 2007
    304
    Thanks for the input.
    I'm not interested in running Linux.. just looking for the smallest board I can find at a reasonable price... I will put Windows XP Pro on it, and run Mach3.. It would be nice if the motherboard carried its own power supply too... not critical but nice to have
    Any other ideas/recommendations out there?
    Thanks to all,
    Joe
    www.CNC-Joe.com
    Feb 2010
    230
    I agree with jalessi, the Intel DG41MJ is a fine motherboard for your needs.
    Check out item # 300446153932 on Ebay. It is a Socket 775 and does have one
    parallel port and one serial port along with Vga onboard. This is the one I would
    purchase if I need a small form factor.
    Regards!
    Regards, Carl
  1. Needed : Motherboard for Summa D60SE
    By Litografa in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 06-28-2010, 03:58 PM
  2. Advice on small cnc
    By bob pfohler in forum WoodWorking Topics
    Last Post: 06-26-2007, 04:57 PM
  3. Need >very< small linear slide advice
    By Stepper Monkey in forum Linear and Rotary Motion
    Last Post: 01-28-2007, 05:08 PM
  4. Best Small Cnc Lathe??? Need Advice!
    By Buzz2 in forum Uncategorised MetalWorking Machines
    Last Post: 08-20-2005, 10:13 PM
