It obviously looks like you got a hefty overvoltage spike, unfortunatly the Y03 is an amplifier fault that can be a few things but in this case hopefully is the power into the amplifier, check the three phase supply to the amps for a lost phase, it is possible it took out the amp, the problem with the Wasino, 85v is symptomatic of a lost fuse and you are reading the backfeed from the other two phases, check as much of the three phase supply as you can at the top and bottom of all power fuse carriers. If there is a difference between the top reading and bottom, you have lost a fuse and hopefully thats all it would be, also check the voltage right at the transformer, bypass any fusing.
Al.
Albert E.
