586,271 active members*
3,726 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > It's Smaller Than It Should Be!!
    May 2005
    37
    Exclamation It's Smaller Than It Should Be!!
    Hi I'm using Kellycam and drew up some text, sent it to the machine it comes out about 1 inch high, when I originally drew it at 12 inches high....... I guess its a servo motor setting somewhere? maybe someone smarter than me can point me in the right direction!....thanks!
    Apr 2003
    361
    Go to Option > Table Setup and make sure it match your actual setup
    Stupid questions make me smarter...
    See how smart I've become at www.9w2bsr.com ;-P
    May 2005
    37
    thanks for your help.......
    Feb 2004
    2337
    Try Viagra.
    Being outside the square !!!
    May 2004
    290
    Quote Originally Posted by ynneb
    Try Viagra.
    Maybe it was the cold water
  1. Smaller Spindles?
    By spoiledbrat in forum Commercial CNC Wood Routers
    Last Post: 03-25-2006, 05:53 AM
  2. Anyone hazzard a guess at the VA rating of this transformer.
    By MrBean in forum CNC Machine Related Electronics
    Last Post: 02-12-2005, 01:03 AM
  3. How to weld plate to tube at 90 degrees?
    By coolman in forum Welding Brazing Soldering Sealing
    Last Post: 12-23-2004, 09:03 PM
