586,089 active members*
3,893 visitors online*
    Aug 2010
    Can not zero out (x) axis on Fanuc O-M
    we replaced all the bearings in our johnford machine and now it will not home out the x-axis....we have tried to do the soft key restart and it has not worked...any help would be much appreciated.
    May 2006
    42
    Is the machine attempting to home but going to the wrong place? You may have to adjust the machine parameters.
    Or is the machine not moving at all? You maybe on a limit switch.
    Aug 2010
    156
    what do you mean by tried a soft key start up?
    You should be holding in two keys the key with the letter "P" on it and the "CAN" key
    (the "P" is on a key that uses many letters) and you power off the machine and push in the two keys
    hold them in until all power is on including hydraulics.
    Then zero return should be ok.
    if not what is the alarm?
  1. Fanuc OM-C 4th axis?
    By TR MFG in forum Fanuc
    Last Post: 09-04-2023, 12:14 PM
  2. Replies: 1
    Last Post: 07-19-2010, 03:11 PM
  3. Fanuc 21mb 4+1 axis want to make 5 axis
    By rebirthauto in forum Fanuc
    Last Post: 09-18-2008, 01:47 AM
  4. Fanuc 18M 5 axis
    By pinguS in forum Fanuc
    Last Post: 06-09-2008, 09:45 PM
  5. Fanuc OT 3rd and 4th Axis
    By thardy in forum Fanuc
    Last Post: 11-29-2006, 05:05 PM
