Originally Posted by
Tristar500
I've ordered a motor. Went with a non water cooled unit and am going to essentially build my own can and bearing end holders. I'm thinking of using an tight fitting end mill holder or perhaps a collet extension in replace of the motors original shaft.
I ordered a motor that turns 80,000 rpm
Yeah, what motor is that? Sounds good. Using a collet extension is what I've been planning as the shaft for a spindle as well. There's a lower limit of size in extensions, which I think is ER-8.
Most distributors here in the states have english sized shafts, but I found a metric source at Somma Tool for ER-8 straight shank extensions. I haven't checked if they have precision balanced ones. the neat thing about that one is the shank is 8mm, so you could use 608 skate bearings.
The DIY turbojet guys have a lot of info on modifying these bearings for stupid high rpm's cheaply, by removing the cages and turning them into full compliment ceramic ball bearings. Though you might find some good ceramics at VXB.
Mike Visit my projects blog at: http://mikeeverman.com/
http://www.bell-evermannews.com/ http://www.bell-everman.com
