586,460 active members*
3,205 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Material properties for carbon fiber tubes in solidworks simulation
    Jul 2005
    450
    I am trying to simulate a structure containing carbon fiber tubing, however it appears that the solidworks materials for carbon fibers are missing a load of properties. Does anyone know where i can find material properties for carbon fiber tubing?
    Does anyone know of a better supplier who might publish such details?
    May 2007
    312
    Quote Originally Posted by daedalus View Post
    I have not done this with Carbon Fiber tube but based upon experience with other materials you will have to do the testing yourself in the lab. Carbon fiber composites have so many variants of the compents I don't believe you would have a very accurate model unless you tested the actual material you intend to use.
    Jul 2005
    450
    Actually I found most of the parameters i needed from these guys: http://www.carbonfibertubes.co.uk/technology.html
    I apreciate that the results wont be anywhere near 100% accurate, and that lab verification will be required. The problem is on the scale i am working, each mechanism has $400 worth of CF tubing in it, so it would be pretty expensive to spec the wrong size.
    My initial plan was to buy a single beam of the material, constrain one end, apply a load similar to my max working load, and check the deflection matches my FEA results. I dont have the equiptment to test it much further then that.
    When the whole mechanism is done i will redo my overload tests with the prototype, as they are required for safety testing anyway.
    Oct 2010
    analysis of carbon fiber tube
    hello dear, i have the same problem, i want to analyzed a carbon fiber tube, i do not have the material properties, just i have the stiffness (90-100 Gpa) and density(1.65 g/cm^3), i want to analyzed this in anys , but i dont know how can i modeled this in ANSYS. If you have got some solution, can you help me in this regard, a help in this regard will be appreciated........
  1. Carbon fiber
    By turmite in forum Composites, Exotic Metals etc
    Last Post: 01-08-2014, 03:57 PM
  2. Tools for machining solid carbon (not carbon fiber)-more posted
    By camcutter in forum Composites, Exotic Metals etc
    Last Post: 04-28-2007, 12:23 AM
  3. Carbon Fiber
    By DrasticSports in forum Employment Opportunity
    Last Post: 03-30-2006, 12:19 AM
  4. Carbon fiber
    By CNC Pro in forum Community Club House
    Last Post: 03-13-2004, 11:32 AM
  5. carbon fiber
    By Hobbiest in forum DIY CNC Router Table Machines
    Last Post: 01-23-2004, 10:40 AM
