I plan on making a small 12x12x2 router from mostly MDF. I'm thinking about laminating .75 thickness pieces to .5 thickness pieces.
I have a larger Aluminum CNC which I can use to cut out the parts on and use alignment holes drilled into the MDF when I cut them, to help keep the parts aligned.
Should I just use normal wood glue to laminate the pieces together? Is there anything I should be watching for when laminating MDF?
